02-05-2015, 01:23 PM | #1 |
*Official* Post a pic of your new truck parts thread.
Figured this would be a good idea for a thread.
Parts have to be new or "reclaimed" for use on your truck. Also, the pictures have you be your own. No use of stock photos or ones from other sources allowed. I'll start. Here are some that came in today. Complete 292 gasket set, carb rebuild kit, water pump (unfortunately showed up broken), thermostat, and bypass hose. (4) airlift D2600 bags, front mounting plates, step notches, some hose and fittings, and a temp ball valve Ok, your turn. Lets see what you got for your truck today... |
02-05-2015, 02:45 PM | #2 |
Re: *Official* Post a pic of your new truck parts thread.
Didn't come today. But to help get the thread started. New 100 amp chrome alternator for my 292.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-05-2015, 02:53 PM | #3 |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
02-05-2015, 03:02 PM | #4 |
i got a "new" title...
02-05-2015, 03:29 PM | #5 |
Cool idea! I got my new steering column and shifter linkage in last week.
You can find me on Instagram @neveno_cten |
02-07-2015, 09:39 AM | #6 |
My new carpet from Stock Interiors!
02-07-2015, 09:55 AM | #7 |
Transmission in a box. Fresh from chrome.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-07-2015, 03:35 PM | #8 |
New chrome grille
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
02-07-2015, 11:06 PM | #9 |
Went to the Kalamazoo swap meet today and started out with these. Then ended the day with getting an 86 rolling chassis from Tennessee with the power booster and dual exhaust.
02-07-2015, 11:23 PM | #10 |
Pic 1 - Entire floor Pic 2 - Entire suspension Pic 3 - Ball joints, tie rods, and energy suspension bushings Pic 4 - Door bottoms L/R
02-09-2015, 09:21 AM | #11 |
02-27-2015, 03:53 PM | #12 |
These came in 2 days ago from Summit. Wire harness and 5 lug swap axles and drums.
Yesterday, I made the drive up to see Pimpston65 and did a little trading. I got a high hump trans tunnel and a sweet rad. Thanks again, buddy. |
02-28-2015, 08:28 AM | #13 |
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
02-28-2015, 09:37 AM | #14 |
If opening the box counts. Here is the test fit of my aluminum grill I picked up at Carlisle last year. With the new headlights I got from summit yesterday. I apologize I have tried half a dozen time to rotate this the right way without luck. So you may have to turn you head sideways to see it.
02-28-2015, 03:45 PM | #15 |
Just need some good weather now
Fed x dropped them off yesterday in the middle of a snowstorm and i work on mine in the driveway no shop
02-28-2015, 06:04 PM | #16 |
Flex-a-lite Black Magic 3300cfm fan. McLeod hydraulic clutch bearing.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 02-28-2015 at 08:55 PM. |
03-01-2015, 03:06 PM | #17 |
Registered Loser
Dang. This thread makes me wanna build another one.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
03-01-2015, 03:56 PM | #18 |
Depressing... Mine runs and I'm wishing I had more parts to put on now.
Seanrolandwood, did you get the 2.02 041's or the 1.94?
At my worst I'm at my best |
03-01-2015, 04:34 PM | #19 |
They're the 2.02/1.60 64cc heads they were redone in august for my dad but he took pitty on me when we found my old heads to be shot, that's what started this winters project of replacing everything underneath from radiator to rear end when it backs out the driveway next weekend that will be the first feet on anything 0 miles on motor trans rearend
03-01-2015, 04:53 PM | #20 |
Sweet! Best of luck to you, go easy on the new stuff for a while and be sure to change the fluids after a few hundred miles. External magnets on the pans helps keep the crap at the bottom of the pans.
03-05-2015, 01:31 AM | #21 |
03-05-2015, 07:38 PM | #22 |
Who Me?
I have to contribute something to this thread.. Great idea!
Here is my new rad I installed a couple of months ago.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
03-05-2015, 08:11 PM | #23 |
15x7 and 15x8 Cragar Delux's and Hankook radials
03-05-2015, 09:32 PM | #24 |
Brake lines for '62 came in. Though not for '62, new projectors for my one ton came in. Lightning idea for others.
03-05-2015, 09:35 PM | #25 |
So I ordered some new parts from summit, theyre wrong. The credit card I used is no longer valid. Can I still return the parts to summit? The parts are not expensive, but I don't need them as I messed up my order.
