Old 02-07-2015, 07:15 PM   #1
cheepin
1987 suburban no crank or start
I have a 1987 3/4ton suburban with the 5.7TBI. Today I went out and opened the door reached in and started it. Started just like normal. NO slow crank or anything. I let it run and walked away. About 20-30 secs later it died and no won't crank or anything. Has power to the lights and such. Just no crank or anything. NO clicking like the starter is going bad. Does have the normal chevy loose tilt steering column. Any help would be great thanks, Brady
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 02-09-2015, 04:23 AM   #2
BLOWN73
Re: 1987 suburban no crank or start
Chevy the fuse to the dizzy
If that's not it check all the fuses
Next step, check any fuseable links
Next if all that checks out it may be an ignition switch ( not the key cylinder but the switch)
BLOWN73 is offline   Reply With Quote
Old 02-09-2015, 10:14 PM   #3
cheepin
I have power to the switch,13volts. I put a new switch in and all the normal dash lights came on. Hit the key and it turned over for a few sec. Then quit and is now doing the same thing. Got dark so I didn't check to see it I still have power to the switch.
Old 02-09-2015, 11:14 PM   #4
BLOWN73
Check to make sure the rod that goes to ign switch isn't bent or broken
Old 02-15-2015, 06:12 PM   #5
cheepin
Anyone have an engine side wiring diagram. I see 2 red wires going into the fuseblock. I assume they are both power. 1 has power the other doesn't. Looks like one goes to the fusible link and is testing fine.
I tested both the new and old switch on my crawler and both are good. Crawler uses an 88 chevy truck column.
Old 02-15-2015, 06:38 PM   #6
463
463's Avatar
Take a look at these http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Trueman
463 is offline   Reply With Quote
Old 02-15-2015, 06:50 PM   #7
cheepin
Originally Posted by 463 View Post
Thanks I found I was wrong both are getting power. Don't know where to look next. I see no visibly damaged wires under the dash.
Old 02-15-2015, 09:15 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
Have you checked the HEI ignition module? Quick and easy to check, if you have a parts chain close by that can test them.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-15-2015, 10:14 PM   #9
Bad Apache
Bad Apache's Avatar
Does the Check Engine light come on with the key on? If yes, check for spark at one plug wire end and check for injector pulse (you'll see it spraying fuel on top of the throttle plates while cranking). If no Check Engine light, look into a loss of power to the ecm. These bad boys are pretty bullet-proof. I've also seen the rotor worn completely through and the spark then kills the ignition module. Let me know what you find and we'll go from there.
1958 Apache 454ci 4 speed
Bad Apache is offline   Reply With Quote
Old 02-18-2015, 12:20 AM   #10
cheepin
Nope that's the problem. I have nothing turning on with the key.
Old 02-18-2015, 08:59 AM   #11
Bad Apache
Bad Apache's Avatar
So no lights at all on the I/P cluster or just no CEL? I have all the service manuals at home for the 87 model trucks from when I had my 87 Silverado. So I'll take a look at them tonight and let you know what I find. Sounds like a fusible link melted off. If you get a chance, tug on each one firmly to see if it failed internally of the insulation. I believe there are some at the starter and some at a junction block under the hood somewhere. And possibly one at the alternator as well.
Old 02-18-2015, 10:17 PM   #12
Bad Apache
Bad Apache's Avatar
I looked at the diagrams, geesh they suck. They don't have any good diagram for power distribution to the starter or ignition switch. I'd still suggest a thorough check of the fusible links and their connections at the starter, battery and alternator output terminal.
Old 02-20-2015, 10:05 PM   #13
cheepin
Nope lights on dash with key on. Do have headlights and dome lights. No power locks or windows. The no power locks confuse me as they have power all the time. Both power supplies to the fuse block have 12 volts. These have fusible links.
Old 02-28-2015, 10:04 PM   #14
rideair
Mine will do the same thing if it is below 9 degrees outside. After the sun hits it for a little while, starts right up. I think mine needs the switch adjusted just a bit.
Enjoy,
Rideair
rideair is offline   Reply With Quote
Old 03-01-2015, 02:11 AM   #15
cheepin
Enjoy,
Rideair
I haven't messed with this yet. But I know the original and new switch are good. Swapped into my crawler they both worked. Crawler has an 88 column.
Old 03-02-2015, 11:36 AM   #16
jetmech85
After replacing ignition switch and still no start, mine turned out to be my three month old new (not rebuilt) Powermaster starter.
jetmech85 is offline   Reply With Quote
Old 03-02-2015, 11:45 AM   #17
BLOWN73
HEI right?
Old 03-06-2015, 12:05 AM   #18
cheepin
Originally Posted by BLOWN73 View Post
HEI right?
Nope stock comp controlled dizzy. This is a TBI set up.1987 first yr.
Still haven't messed with it. Hopefully this weekend.
Old 03-02-2015, 11:48 AM   #19
Merritt Broughton
Is there an ignition control modual under the dizzy I have had similar problems and thats whAT IT TURNED OUT TO BE FOR ME 40 bucks at the part store and 20 mins work,back on the road or check your power and ground from starter celunoid maybe they need a good cleaning
Merritt Broughton is offline   Reply With Quote
Old 03-06-2015, 12:26 AM   #20
BLOWN73
Grounded tach wire? Unplug the tach wire on the dizzy
