Old 02-09-2015, 11:55 AM   #1
billye1982
Roof repair
I have a 66 short wide with the worst roof skin I have ever seen but the floors are perfect, I also have a spare cab with a good roof, but horrible floors/rocker. I know the rocker/floor repair is a lot more common, but how hard is a roof skin repair? How is it attached, is it spot welded, or welded along the seam of the drip rails and such? The one with the bad roof looks similar to this all the way around, so it is not just this one section.
billye1982 is offline   Reply With Quote
Old 02-09-2015, 01:29 PM   #2
PGSigns
PGSigns's Avatar
Re: Roof repair
I would just fix the red cab. Parts are easy to get and much easier to do than cutting the top off the truck. When that are that bad the rust is usually bad a good way down the pillers.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-09-2015, 02:45 PM   #3
Branman1971
Branman1971's Avatar
Re: Roof repair
I'm in the middle of a roof and drip rail repair and it aint easy but I'm an amateur body work guy. I'm patching the bad spots in my roof with pieces cause I didn't have a complete good roof. The roof is held on with lots of spot welds after you dig out all the sealant. I got a bunch of spot weld bits from Harbor Freight and it does a good job.
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 02-09-2015, 04:36 PM   #4
4mulaSvaliant
4mulaSvaliant's Avatar
Re: Roof repair
To answer your question the roof is spot welded all the way around the seam. I have done a few major cab panels and they aren't that bad really. But as I said I have done a few now, so my fear level isn't as high as it was! LOL
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 02-09-2015, 10:38 PM   #5
LT1 Burb
LT1 Burb's Avatar
Re: Roof repair
150 plus shipping
LT1 Burb is offline   Reply With Quote
Old 02-10-2015, 01:51 AM   #6
Captainfab
60-66 Nut
Re: Roof repair
I would highly recommend cutting in the middle of the A and B pillars as you will need much more than a roof skin. This will require attention to window opening dimensions.
