Old 02-09-2015, 05:01 PM   #1
4mulaSvaliant
4mulaSvaliant's Avatar
BATT light staying lit. :/
So yesterday we had a nice day here in Virginia Beach. I threw the yellow Lab in the truck and rolled around town.
As I am rolling do the road, some smartguy decided pulling out in front of a truck moving 50 mph was a wise choice.
I got on the brakes pretty hard and immediately after, my BATT light was steadily lit.
I pulled over right away, thinking that maybe my alternator plug had come lose or something.
All check out ok under the hood, and so I cautiously carried on back toward the house. At this point I fully expected the truck to kill the battery before I got home figuring that the charging system was not functioning.
I made it all the way home, checked a few more things visually (it was getting dark so I couldnt do much more)
I expected to come out this morning to a dead battery thinking maybe a wire was pinched in my abrupt hault. No dice there either! She started just fine and rolled to work like usual.
So now I am at a loss. I have yet to check voltage anywhere, so I am not sure of charging voltage yet.
I looked over all the plugs and followed the wires to make sure they were all connected as they should be.
Ill try to get that done this eve.
Specs:
64 C10
84' 350
84' alternator
no gauge, just the lamp. :/
Thanks guys. I am not sure where to look next.
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 02-09-2015, 05:36 PM   #2
Wrenchbender Ret
Re: BATT light staying lit. :/
You probably have a shorted diode in the alt. They will still charge like that but not full capacity. If you like to do you own work they are pretty easy to tear down & test.
Wrenchbender Ret is offline   Reply With Quote
Old 02-10-2015, 08:23 AM   #3
4mulaSvaliant
Turned out to be the regulator. It has been in the back of my mind to have a spare on hand, as I know they are a fairly common failure. Figures aye! Hahahahah
Thanks for your help WrenchbuilderRet
Old 02-10-2015, 10:27 AM   #4
4shongo
That is what it was on my 66 as well when that happened. Glad it was a easy fix.
4shongo is offline   Reply With Quote
