02-10-2015, 03:35 AM | #1 |
Old member
Fuel pressure gauge extenstion
Hey guys anybody know of a gauge extenstion for my feul gauge on the motor. Now that I have the cover over the motor I can't see the gauge was wondering what you all have done for this?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-10-2015, 09:59 AM | #2 |
Boosted Member
Re: Fuel pressure gauge extenstion
Take the cover off if you need to see the fuel pressure?
It's not something that is needed unless you have to troubleshoot. Anyway, it should just be a -4 AN fitting on the rail, pull your gauge, get a hose that's the correct length, and move it where you want it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-10-2015, 02:44 PM | #3 |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-11-2015, 11:27 PM | #4 |
Why do you care?
These motors have a very narrow window for acceptable fuel pressure - it'll let you know if there is a problem well before you have a bigger problem. I don't monitor it on mine beyond keeping a loose eye on the wideband.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
02-12-2015, 12:02 AM | #5 |
Old member
The only reason I like it it lets me know when the check valve is going out on the pump. If the gauge is low then the check valve is not working at the pump which in turn makes it take longer to crank. And just because I have it on the motor I may as well beable to see it!
