02-12-2015, 04:07 PM | #1 |
5" drops and panhards???
so I ordered a set of cpp 5" rear drop springs from summit today, and an adjustable panhard bar, but now I'm not sure if I got the right panhard bar. I ordered this one...
http://www.summitracing.com/parts/wst-316572 I was reading somewhere that if you drop x-amount of inches you have to move the panhard bar location... please advise
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
02-12-2015, 04:48 PM | #2 |
Re: 5" drops and panhards???
if you drop more than 4" its alot better if you use the super panhard bar
1967custom |
02-12-2015, 05:29 PM | #3 |
Florida Edition
That's the correct one. You also need a shock relocator kit.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-12-2015, 05:32 PM | #4 |
Moderator
I have a 7" rear drop and use that exact same trac bar. You will be just fine.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-12-2015, 09:00 PM | #5 |
I got the 5" rear drop kit from Early Classic, and the kit came with longer bar and separate mount for between the axle and the arm stating a 5" drop with standard length /location panhard would offset the rear. Also, as stated the shocks came with a relocating kit stating the drop will cause stock location of shocks will bind.
I just gotta get out here and do it, why? Cause nobody will do it for me... |
