Old 02-12-2015, 05:45 PM   #1
happyhunky
Wiper ground
On a 57 factory electric wiper setup, do I need to run a ground wire or will the mounting in factory brackets suffice or the ground?
happyhunky is offline   Reply With Quote
Old 02-12-2015, 06:16 PM   #2
octanejunkie
octanejunkie's Avatar
Re: Wiper ground
That is a good question
I believe the units were internally grounded (grounded off the cab mount) but if your motor housing or mounts are rusted you may want to attach a ground wire to be sure.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 02-12-2015, 07:42 PM   #3
OrrieG
OrrieG's Avatar
Re: Wiper ground
Yes, wiper body grounds thru the bolts to the cab. rust or fresh paint will keep it from grounding. If painted chase the threads with a tap. If rusted add a ground wire from housing bolt to good bare metal.
Old 02-12-2015, 07:56 PM   #4
Clarance J
Clarance J's Avatar
Re: Wiper ground
Here are some pictures from my 55.2 wiper motor that I finished working on recently. It does need a ground wire if you have the rubber vibration grommets installed. Maybe the mounts changed by 57, I'm not sure but a ground wire wouldn't hurt.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
