Old 02-13-2015, 02:08 PM   #1
clemsonteg
Track bar frame mount
Anyone have a custom track bar frame mount or used something other than the factory bracket. I need to drop my track bar down a few inches on the frame side in order to reduce the angle on my track bar.
clemsonteg is offline   Reply With Quote
Old 02-13-2015, 06:52 PM   #2
SCOTI
SCOTI's Avatar
Re: Track bar frame mount
http://67-72chevytrucks.com/vboard/s...d.php?t=368476
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-14-2015, 10:25 AM   #3
dec010974
dec010974's Avatar
Thanks again SCOTI. That is definitely doable. and to think I was gonna buy one (PHB).
dec010974 is offline   Reply With Quote
Old 02-14-2015, 12:11 PM   #4
SCOTI
SCOTI's Avatar
If you're a DIY'er, this info can build the whole enchilada (for up to 8" rear c-notch style drops)....
http://67-72chevytrucks.com/vboard/s...d.php?t=523723
http://67-72chevytrucks.com/vboard/s...d.php?t=450565
Beyond that, the truck arm mount wouldn't work integrated into the lowering block & be level @ ride height. Most likely, it would need to be part of the T/A.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-14-2015, 10:07 PM   #5
clemsonteg
Thanks Scoti. Probably more than my fab skills are capable of. I'll probably sell the track bar I have now and invest in a PB bar when I do a C-notch.
Old 02-16-2015, 04:42 PM   #6
Wild83C10
Wild83C10's Avatar
Here's a few shots of mine. Pretty simple. I used a piece of diagonally sliced tubing to make the angle. It's a CPP track bar, now double adjustable, with a CPP bracket on the truck arm.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-10-2015, 09:06 AM   #7
clemsonteg
I am coming back to this now that I have redone part of my suspension. I am considering taking the rivets out of the current mount, installing some sort of spacer and remounting it to the frame with grade 8 bolts. Has anyone done this? My only concern is the force which would be applied to the bolts, especially considering the force will be applied 2-3" from the frame. I am thinking I could use a piece of rectangular tubing as the spacer.
