Anyone know what could cause antifreeze in radiator to be almost like a salmon color? Went to check the level and its a weird color asked a mechanic and was told previous owner probably added some sort of stop leak additive. It does not look like rust. Any advice is greatly appreciated. Thanks in advance.
90 350 TBI
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Re: redish color in radiator?
Is the additive dangerous to other things, seems like a bad idea to do this.
Likely the previous owner switched to long life coolant such as Dexcool.As long as system was flushed you should have no issues.If you have to add coolant be sure to use a universal type and not the green ethylene glycol.
Is it milky as well? Could be trans fluid mixing if it has a trans cooler in the radiator.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
Stop leak is a bad idea most use it to fix a leaking head gasket,And its good at stopping up water passages and sometimes radiators.Look down inside the radiator does it look nasty and sludge or clean and smooth?
Cruzzzn' Vet
Dump and flush, refill with green
Not milky. That was my first thought about trans fluid mixing. I'll get a closer look today. Thanks guys!
#8 | |
78K & 79C Jimmys
Flush ASAP not likey tranny fluid,I'd think the higher pressure would blow the rad cap, no?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
