02-15-2015, 11:55 PM | #1 |
s10 Transadapt motor mounts?
Anyone running these mounts on your s10 conversion on a 47-53 If so do you have any pics installed?
02-17-2015, 04:48 PM | #2 |
Re: s10 Transadapt motor mounts?
The S10 conversion mounts are meant to move the motor forward not back. You need to move the motor back.
I did buy a similar set and though I could simply swap them side to side to position the motor back. However, the fuel pump casting interferes with this. So, I put the S10 conversion mounts on the chassis and the rubber motor mounts on the motor. One other problem, at least on my chassis, the chassis motor mount bolt holes are not symmetrical. This is why the S10 2.8L motor mounts have slots in them and the Corvette style have holes. You an install the top bold then drill the other two or weld the S10 conversion mount on. I'm planning on welding mine on after I get the cab on and the engine where I want it. I picked mine up on eBay for $25 shipped. Otherwise, I don't think I would have experimented with it. I have pics of the S10 conversion mounts and the Anchor 2436, 1990 S10 2.8L and Anchor 2713, 1990 Corvette in my signature link. Hope that helps. Anchor 2436, 1990 S10 2.8L Anchor 2713, 1990 Corvette |
02-18-2015, 01:15 AM | #3 |
Hussey Thank you for the Info.
