Old 02-16-2015, 01:26 PM   #1
jdalexa84
three on the tree linkage
I am looking for linkage to get rid of a bad floor shifter and I have found someone who has the parts but I read that if you have a v8 then you have to get linkage from a v8 not I6. Is this correct or are the the same? Any help is appreciated
jdalexa84 is offline   Reply With Quote
Old 02-16-2015, 01:31 PM   #2
FlameOut
Re: three on the tree linkage
I swapped out my 250 6 cyl for a 350 v8 on my 72 K10 and I used all of the same original parts/linkage from my manual 3 speed column with no problems. I'm not sure if a C-10 would be different. My engine swap dropped right in, but I've heard it's a little more complicated doing the swap on theC10
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 02-16-2015, 02:06 PM   #3
flipper58
flipper58's Avatar
Not sure of the answer, but if you end up needing V8 linkage, I have that off of a 69 column shift 3 speed, if that is what you are working with. And I am located just south of you where it was much warmer this morning, -6 degrees.
flipper58 is offline   Reply With Quote
