02-19-2015, 06:03 PM | #1 |
Disc Brake Xmember Swap Verification-Blazer
Went thru the 60-66 FAQ's... everyone "mentions" the later model C10 crossmember swap to get 5 lug and disc brakes...
I would like to VERIFY that a 1987 BLAZER 2wd retains the same geometry... I have a hit on a completey assembled Xmember front up here but its off of a Blazer and I want to ensure that the blazer retains the same GEO up front (since its a rear leaf chassis even tho its 2wd) 87 BLAZER frame the same as a C10 frame? Any other issues with using 1987 Blazer front Xmember/brakes/arms etc? when integrating into their 1960-66 C10 frame besides the standard elongated the holes?
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
02-19-2015, 06:52 PM | #2 |
Re: Disc Brake Xmember Swap Verification-Blazer
If you're truck is a 66 why the change? There are brake kits that do this and don't have to use old parts but new. Or swap ball joints to later ones and use new spindles. http://www.classicperform.com/Chevy-Truck.htm
The crossmember is pretty much the same. No real gain.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-19-2015, 06:55 PM | #3 |
67-72 parts collector,…
Last year of the FULL SIZE 2wd blazers was 1982.
Are you talking about an S10 blazer? They are totally different.
02-20-2015, 12:42 AM | #4 | |
S10 blazer wasnt unitl the mid 90's 1987 Blazer
02-20-2015, 07:27 AM | #5 |
First year of the smaller S10 blazer was 1983 (thru the 1994 model year).
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-20-2015 at 11:42 AM. |
02-20-2015, 01:24 AM | #6 |
1961 crewcab
yes blazer and suburban used the same body and frame until 1991, the truck switched to the new body style in 88, and the blazer and suburban in 92.
so the 2wd blazer cross member should interchange 1973 to 1991! I used an 88 sub x-member on my wifes 63 with no problems
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-20-2015, 01:53 AM | #7 |
I hope it works or i have wasted a lot of time and cash, Putting a 79 2wd suburban crosmember under my 63
02-20-2015, 01:58 AM | #8 |
60-66 Nut
The '73-'87 C10,20 and 30 pickups, '73-'91 C10,20 Suburbans and '73-'91 K5 Blazers are all based on the same frame and same suspensions.
02-20-2015, 06:52 AM | #9 |
Am I the ONLY one reading "87 2wd blazer"?
The last GM production year for two wheel drive blazers was 1982. The one pictured is a 4x4 blazer. What am I missing?
02-20-2015, 11:14 AM | #10 | |
Nope I got what your saying now... I will be verifying with seller to see what EXACTLY I'm looking at (he has no pictures) There is NO 1987 blazer C10 only K5 (4WD) Interstesting... thanks for flagging with me... hoping hes just a typo in the description
