![]() Join Date: Feb 2015
C notch dillema
Here is my dilemma. Previous builder c notched the frame in the wrong place, 2.5" too far forward. He also built a ladder bar that is lethal by design.
and shortened the drive shaft. I have a new cantilever, fourlink laying on the shop floor to install. KP setup. I need some way to measure the rear axle to locate it properly so I can correct the c notch, and install the canti setup. Measuring from the front hub is a little suspect as it is terribly aligned. TOE IN like 1-1.5" Suggestions please. IC |
#2 | |
Re: C notch dillema
Nothing is foolproof because fools are so ingenious. Good Luck! Last edited by Fitz; 02-22-2015 at 04:38 PM. |
Re: C notch dillema
Ahh yes! Silly me! 1972 GMC LWB
Thank you for the reply. I will study the diagrams. IC |
Re: C notch dillema
Where did you get those diagrams because it would be nice to have a set on hand for when I'm working on my frame.
1968 C10 SWB "Rosey" |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: C notch dillema
The ony REAL way to know is to install the rearend and center the wheel in the bedside.
Your KP 4-link should have the correct instructions to install the 4-link front bracket. Get the wheel to LOOK correct in the wheel opening and then install your notch. Some of these trucks have the wheels too far forward or rearward when dropped to an extreme amount with factory components. You have the chance to correct that with your KP kit. http://www.cachassisworks.com/Attach...27-4LBOC31.pdf
Re: C notch dillema
http://www.cachassisworks.com/Attach...27-SNBOC31.pdf
Actual notch installation instructions,...
Re: C notch dillema
Thank you Keith. Now for my next question.
When I ordered this assembly I specifically stated C notch, I revd. a step notch. I do not want to cut into the bed floor nor do I want to lower it that much. Did I screw up by ordering this kit? Do I have to use a step notch for the canti four link? Thank you again. IC |
Re: C notch dillema
The KP 6-link (4-link with a cantilever) is for an extreme notch.
The cantilever set up take a small bag and doubles the amount of lift you can acheive. (as in from the ground up to ride height) You can use the 4-link by itself with a small c-notch, but this isn't going to get you much lower than a factory trailing arm set up. What are you trying to do with your truck? Maybe you should explain from the begininning. Leaf spring rear suspension or coils? Just trying to get the BIG picture?
Re: C notch dillema
Here's your set up with a fabricated step notch.
Re: C notch dillema
And down,...
Re: C notch dillema
Ahh the big picture. Sent the truck to a builder 3 1/2 years ago to be built for my sons graduation, 2 years ago. last month recovered the truck in an unfinished and seriously disappointing state.
We were hoping for a 4/6 drop. I had decided to bag the truck, hence the KP canti four link. As stated earlier. the C notch is too far forward and the homemade ladder bars were lethal by design, so I am totally scrapping them and starting over with an engineered setup. We no longer have the trailing arms or any of the associated hardware. |
Re: C notch dillema
Lolife99. Thank you for the pic.s. We are not trying to lay that low at this time. This is North Dakota, our highways aren't that smooth. lol I have not yet figured out how to post a pic in a post but if you would, look in my photo album on this site and you will see the photo I just took of one side with the rubbing coilovers and C notch. thank you
IC |
Re: C notch dillema
I would install what you have and index everything off the KP front mount like the KP instructions say.
Then add a small c-notch. You may have to fill in the old notch to regain frame strength, since I don't know what your current notch looks like. You just wont be able to air the truck out as low with the c-notch, but your ride should be fine. Here's your pic,...
Re: C notch dillema
Lolife69 Thank you for all your input. Am I on a wild goose chase here or is the canti setup the way to go. I read a lot on it and was under the impression I would be able to get lower with that.
The reworking of the c notch is not a problem. I intend to plasma cut out the old notch and fabricate my own or maybe buy one and reinforce it with thicker inner box. I intend to weld the entire thing in. relocating the shocks may be a little tricky as the picture shows the tank on the left side of the pic. The exhaust will be another piece of the puzzle. Thanks again IC |
#15 |
Re: C notch dillema
Since you don't want to be too low get yourself stock trailing arms and just fix the c notch. You cab get a basic rear bag setup from porter built and call it good.
Sell the KP setup and recoup some of your $$. Here is my truck with a c notch and basic air bag system. Axle sits inside the notch. |
#16 | |
Re: C notch dillema
Any more than a c-notch will require you to cut the bed floor. Even a c-notch will put the center section of the rearend right against the stock floor. YOU are going to have to decided what you want. Personally these trucks can achieve a 7" rear drop with the stock trailing arms and coils or a 2600 double convoluted air bag. I would use Porterbuilt products. They are the BEST in the business for C10 trucks. Mild to extreme they have it all. www.pbfab.com The KP kit puts a lot of stress on the rear frame rails,... so your frame repair/notch is going to have to be stout. I agree. I would sell the KP kit and do some more research. Also Porterbuilt has one of the strongest notches in the business. Check them out.
