02-25-2015, 10:59 PM | #1 |
700-R4Transmission Cooling
Gents,
I have the following: HBR (LasVegas) 383 Stroker built for low end (425 HP, 415 FtLbTq maybe more? not sure till the dyno) 700-R4 Transmission, built for towing (Vette servos yadda yadda) Hughes lockup converter GM22LXTM Hughes transmission cooler HP8231, with fan RnD Radiator with transmission cooler option My question is: What is the best way to run these tranny lines? I know that I will be generating high transmission / converter temps because of hauling those darn horses around the high country, but also, long trips in cold north country unloaded. I want the optimum transmission temperature. Should I go transmission to radiator to transmission cooler? I have thought about a 3 way valve to cut in and cut out the transmission cooler depending on temperature. Schematics are great / or verbal. Any thoughts greatly appreciated.
72 K10 |
02-26-2015, 01:53 AM | #2 |
Re: 700-R4Transmission Cooling
Did mine trans to radiator to trans cooler.
02-26-2015, 02:59 AM | #3 |
That was my first thought as well.
What about expected temperatures? Leaving the transmission, leaving radiator, then cooler?
72 K10 |
02-26-2015, 11:00 AM | #4 |
On my vehicles with add on trans coolers, I block them off with a piece of cardboard in the wintertime.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
