08-26-2003, 01:15 PM | #1 |
Will 78' suspension bolt to 71" frame?
have a chance to get a 78' Chevy truck and want to know if the 1/2 ton cross memeber and suspension will bolt up to the frame on my 71' gmc 3/4 ton. i want to keep disk brakes but would like to have 6 bolt wheels instead of the 8's on my 71'.
thanks ronniej |
08-26-2003, 01:18 PM | #2 |
GYRO GEARLOOSE
yes, with a little redrilling of 2 holes
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
08-26-2003, 05:03 PM | #3 | |
CCRider
Re: Will 78' suspension bolt to 71" frame?
If it is a 78 2wd it will have 5 bolt wheels
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
08-26-2003, 06:49 PM | #4 | |
Fabricate till you "puke"
Re: Re: Will 78' suspension bolt to 71" frame?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-26-2003, 09:33 PM | #5 | |
Workin to live...
Jason |
08-26-2003, 09:43 PM | #6 |
PROJECT 7DEUCE
78 foot LOL Ya it will bolt up with little work..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-27-2003, 09:54 AM | #7 |
my fault. it is a 79' chevy.
08-27-2003, 12:02 PM | #8 |
lol........welcome to the board from Virginia! BTW, a 79 feet doesn't work either. hehe (j/k)....78, 79.....they're the same. You'd be surprized at how many years/parts are interchangable.
08-27-2003, 12:33 PM | #9 |
67-72 Addict!
So the 78' front end will work and then you just add 6 lug rotors to it?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-28-2003, 07:33 PM | #10 |
Interested in doing this conversion for disc as well as power on the brakes....anyone have any pics of these two bolt holes that have to be changed? Thanks.
08-31-2003, 01:43 PM | #11 |
it is not hard swap, you will see the two holes you will needto egg out, its easy
control arm bushings on 1/2 tons changed to rubberin 73, 72 and older 1/2tons were still solid ones, 3/4 ton all years still steel, also 1 tons too you will need the 79 balljoints and can uset he 79 hoses too, re route your steellines, 73-up hoses are longer and cheaper |
