Old 03-03-2015, 06:30 PM   #1
CST10
CST10's Avatar
Engine noise after deiseling event! Help!
I recently had a deiseling event on my 68 c10 250 engine. Never happened before. I use premium gas all the time and timing set at 8* BTC. Anyway, after I started it up and drove on home but notice a slight ticking noise. I don't remember this noise before. Couldn't pin point the tick with a stethoscope or by ear.
What could it be? Any ideas? Looking for advise how to check for damage OR what could have been damaged.
Hopefully it's a lifter or rocker or just my imagination running wild.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 03-03-2015, 07:32 PM   #2
swamp rat
swamp rat's Avatar
Re: Engine noise after deiseling event! Help!
I'd say your timing is out, or if your engine is a stock build you are burning Ppremium gas for nothing, both can cause detonation. was the tick on acceleration? Dieseling is also an indicator of a timing issue.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-03-2015, 08:08 PM   #3
CST10
CST10's Avatar
Never deiseled before at the current timing setting and fuel. Premium should suppress knock but the tick increases as RPMs increase. I've only noticed it idling in the shop. Opened the hood and increased RPMs while in neutral and tick increases also. Have not driven it since I noticed it yesterday.
A mechanic I trust indicated that it could be carbon build up in the cylinder and a piece broke free and stuck to the top of the piston making the noise when on compression stoke. He also said it could have damaged a lifter and colapsed or a cracked rocker.
Just wondering if anyone one else had the same issues and what was the problem.
MyToys:
Old 03-03-2015, 08:09 PM   #4
CST10
CST10's Avatar
It's a stock built 250 engine. Never been rebuilt with 22k original miles
MyToys:
Old 03-03-2015, 08:23 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Stock I6 should not need Premium fuel. If you must run a high octane, you can even cut back to 89.
Another thing to look at is exhaust leaks. Many a small "tick-tick-tick" that increases with RPM turns out to be an exhaust leak. Could be at the donut seal.
Gary
EDIT: I thought I was seeing double... I was in the engine and drivetrain section and saw this post and couldn't figure out where my response was. No real need to post in multiple forums.
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-03-2015, 10:10 PM   #6
CST10
CST10's Avatar
Thanks for the info. I'll check the exhaust for leaks too. Didn't think of that possibility.
MyToys:
Old 03-06-2015, 01:55 PM   #7
CST10
CST10's Avatar
UPDATE:
I pulled all the plugs, appears to be running on the lean side. I then fired it up and checked for exhaust leaks and didn't find any. Then I was finally able to narrow the ticking noise down to the mechanical fuel pump. Shut it down and it deiseled again. Decided the check the timing and found that it had move to 4* ATDC, I had set it at 8* BTDC when I did the HEI upgrade a few weeks back. Checked the dizzy hold down bolt and found it barely snug. Loosened it up adjusted timing back to 8* BTDC without VA hooked up. Adjusted the idle speed then the idle A/F mixture. Shut it down. No more deiseling. Drove it for about 20 miles, still no deiseling and fuel pump noise is a little quieter.
Thanks everyone for the advise.
MyToys:
Old 03-14-2015, 10:41 AM   #8
MagmaJct
MagmaJct's Avatar
Very few things cause dieseling. One of them is not ignition timing. Think about it, dieseling occurs with the ignition turned off. That is, unless one is considering the temperature of the spark plug if the timing is too advanced. I suppose then it's conceivable timing can contribute, if the plug is hotter than normal.
I have recent experience with my truck dieseling, I'll share for further reference. Driver's side donut had been leaking for some time. Truck is driven infrequently, so it hadn't been an issue. I ended up finally doing the repair, and found the idle to be rough afterwards. In a pinch I upped the idle speed to compensate.
Know what happened? It started dieseling! Warmed it up, adjusted the fuel mixture, set the idle. Now it idles great, doesn't diesel. Exhaust leak is gone, sounds wonderful!
In my experience, dieseling is caused by incorrect fuel mixture and/or high idle speed. (I am curious, if the high idle speed directly causes dieseling, or if it has more to do with the alternator back-feeding the ignition?)
As an aside, my old VW Beetle has a idle stop solenoid in the carburetor to prevent dieseling and wasted fuel from being sucked into the intake between the time the ignition is shut off and the engine stops rotating.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 03-14-2015, 11:02 AM   #9
CST10
CST10's Avatar
I agree with you. May be the timing and plugs might have been the issue. After I set the timing and cleaned the plugs. I also decarboned the engine using the water trickle trick then lowered the idle down and adjusted the A/F ratio.
Been driving it as my DD all week. Never has had another dieseling issue again.
Don't really know which one corrected it, guess the fuel carb adjustments made it go away.
Engine runs so quite now you have to open the hood to see if it's running if your in a spot where you can't hear the exhaust note. Got a quite muffler on it.
MyToys:
Old 03-14-2015, 11:51 AM   #10
MagmaJct
MagmaJct's Avatar
Talking Re: Engine noise after deiseling event! Help!
Ooo, quiet muffler eh? What kind do you have? Unlike perhaps 95% of truck owners out there, I prefer quiet!
I've got a set of Turbo mufflers from the PO, not a fan of them, but being broke is my motivation for keeping them!
--Mike
Old 03-14-2015, 12:29 PM   #11
CST10
CST10's Avatar
I got the biggest diameter and length round shape muffler the shop had. I asked for the quietest one they had and they said round ones with the longest length and diameter makes them quiter. It's just a no name brand stock style muffler. Not a turbo or anything. I'll be under the truck tomorrow and see if they got a name on it, don't remember one being stamped but may be I over looked it. Think I paid $40 installed.
MyToys:
Old 03-14-2015, 03:35 PM   #12
Longhorn 70
Longhorn 70's Avatar
Glad you got the dieseling under control. Kind of a bummer that you don't know which resolved it. But don't look a gift horse.....
I did the quietest on mine too.... Went to the shop I always go to. Asked the guy for the quietest 2.5" inlet and outlet. Run then from the headers and dump them right before the rear end. They are quiet in the truck. Outside I am told they are noisy but I don't hear it that much. They are ovals tucked up tight.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-14-2015, 07:07 PM   #13
CST10
CST10's Avatar
Well this old I6 is a quite motor to begin with. Now the 462 bob in the 70 is another story. Couldn't make it quite unless you turn the key off. Lol.
MyToys:
