03-05-2015, 09:51 AM | #1 |
Gas tank filler Grommet
I replaced the filler neck grommet 6 months ago when I had the tank out. It has already degraded and falling apart. I bought a new one that is suppose to be better from GMCPaul. Question is: Has anyone removed/replaced the grommet without removing the tank or do I already know the answer? Thanks
03-05-2015, 09:58 AM | #2 |
Re: Gas tank filler Grommet
pull the tank
03-05-2015, 10:00 AM | #3 |
That's what I expected to hear!
03-05-2015, 10:13 AM | #4 |
You can replace the grommet with the tank in place. Use masking tape and plastic tools to work it in place to avoid scratching the paint. Helps to lube it up with some soap or windex.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
03-05-2015, 10:17 AM | #5 |
I just installed one with the tank in place, place the gasket in hot, soapy water (lots of soap), and I gently worked it into place with a flat screwdriver.
1970 Chevy Custom C/10 Dark Bronze & White, 406 C.I. SBC, Edlebrock Cam, Intake, TH350 Trans with cooler, Headman Headers, 2.5" dual exaust with 28" glass packs, 3:73 gears, Original Oak bed, Pace Edwards Roll Top Toneau Cover, Resounds Bluetooth Radio, Chevy rally wheels, 265/75R15 General AT2's |
03-05-2015, 11:45 AM | #6 |
Moderator
You can remove an install a gasket easily with the tank in place.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
03-05-2015, 10:01 PM | #7 |
Awesome, thanks for tips!
03-06-2015, 09:38 AM | #8 |
I installed one with the tank in place, and it didn't seem too difficult - but then I realized I'd put the thing on inside-out. Oh well - it still looks OK that way, and it's easier to get that thing installed inside-out if you are installing it from the "wrong" direction.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
03-06-2015, 10:32 AM | #9 |
And buy a grommet from Wes here on the board and it will not crack.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
03-06-2015, 01:48 PM | #10 |
Yep bought the Grommet from GMCPaul that's not suppose to crack. Put it on this morning, no problem. Thanks guys!
03-06-2015, 01:55 PM | #11 |
Which method did you use? Any special tools? Any difficulties?
03-07-2015, 09:06 AM | #12 |
All I had was some WD40 and a plastic trim tool. Went in fairly easy, no problems.
03-08-2015, 04:31 AM | #13 |
If all that fails heat up the gromet and use some KY jelly. but you got it on.
