Old 03-06-2015, 07:04 PM   #1
Squareforceone
Squareforceone's Avatar
4x4 rear axle in 2wd?
I found a good deal on a 3.73 posi rear end out of a 1980 1/2 ton I really want that rear gear set in my 1984 1/2 ton I know the 4x4 is 6 lug instead of a 5 lug. Is there an easy way to make 4x4 axle 5 lug? Or could I just take the gear set from the 4x4 diff and put it in my 2wd housing?
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 03-06-2015, 07:12 PM   #2
greg64
greg64's Avatar
Re: 4x4 rear axle in 2wd?
With those years, I'm thinking both axles are 10 bolts, correct? Round diff cover?
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-06-2015, 07:22 PM   #3
Squareforceone
mine is not sure on the 4x4 one.
Old 03-06-2015, 09:20 PM   #4
1774btcrew
1774btcrew's Avatar
If they are both 12 bolts you can just switch the axles. If they are 10 bolts it is the same deal. If one is a 12 bolt and one is a 10 bolt you are out of luck
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
