Old 03-07-2015, 10:44 PM   #1
Hiluxxulih
Hiluxxulih's Avatar
SPID with the fewest options
Any SPIDs out there with no options ?
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
Old 03-08-2015, 07:10 AM   #2
Pine Bark Auto
Re: SPID with the fewest options
I'll bet there are quite a few. In the mid to late 70's when I worked at a dealership, we usually had at least 1 "price leader" on the lot. If you ran an ad in the paper stating "New Chevy Trucks as low as XXXX.XX, you better be able to show you have or had at least 1. They were not that hard to sell. Great starter vehicle for younger guys (and gals) that were going to aftermarket wheels, tires, stereo, etc. anyway. Many were ordered in the brighter colors like red, blue or yellow just to appeal to those buyers. I seem to remember lots of red ones. Chip.
Pine Bark Auto is offline   Reply With Quote
Old 03-08-2015, 10:18 AM   #3
Keith Seymore
Keith Seymore's Avatar
Subscribing.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 03-08-2015, 10:56 AM   #4
Hiluxxulih
Hiluxxulih's Avatar
A few years ago there was a Chevy truck like that for sale on Craigslist here in high desert country of Oregon it was a 1987 v6 no power steering no power brakes and three on the tree , if it would have been a long bed I would have bought it .
Old 03-08-2015, 03:46 PM   #5
brakenit
Active Member
My '84 Custom Deluxe had a 250/3 OTT, manual brakes and manual steering and "standard rear axle". There are a total of 12 lines on the SPID including the model but unfortunately it wasn't stuck very well to the inner fender and it allowed a bunch of dirt to accumulate under it making it hard to read.
I am somewhat confused by the 1N51 option that says "POWER STEERING NOT", is that the normal RPO code for manual steering?
brakenit is offline   Reply With Quote
Old 03-08-2015, 08:24 PM   #6
c10sport
c10sport's Avatar
This is from a 1973 in my files, which I am still working on.
Say Keith Seymour, I have a plant question. I am running the 454SS registry (yes, in addition to my SPID project, I have WAY too much free time) and there's a guy claiming to have the second 454SS built. However, his VIN says otherwise, the last 6 digits of the VIN for the second 454SS I have in my database is 139514, his truck is 156538.
So did the plants randomly pluck trucks off the line and give them a higher VIN sequence than the trucks before and after it?
I know the answer, I am just wondering what your thoughts are.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 03-08-2015, 09:08 PM   #7
Keith Seymore
Yes. RPO N51 is the code for manual steering (ie "POWER STEERING NOT DESIRED").
K
1979-1986
1986 - 2019
Old 03-08-2015, 09:33 PM   #8
Keith Seymore
“Randomly pluck” is kind of an improper visual, so let’s review a bit and then I’ll give my opinion:
Vehicle orders come into the plant and are tracked by the “Dealer order number”. Once the order is approved and the build is scheduled it is assigned either a Carrier Sequence Number (CSN) or Primary Vehicle Identifier (PVI). One of these numbers will be used to track the vehicle through the body shop build and through paint. Once the vehicle is ready to drop from paint into Trim both the VIN and the General Assembly (GA) sequence number are established. The GA sequence number is the gold standard for tracking the build within the assembly plant; the VIN is never mentioned other than to make sure the correct one is installed on that GA sequence number, just like a tune up label or Mulroney window sticker or SPID label. Nobody in the vehicle assembly plant really cares about the VIN (unless it gets messed up).
Having said that the vehicles drop down roughly in VIN sequence, but with the following caveats:
a) Different nameplates can have different VIN sequence starting points, so Chevys increment in one “family” but GMCs or Cadillacs (or Pontiac or Oldsmobile) are incrementing up in a separate cadence.
b) Vehicles can be held up after the VIN is established, for example if the vehicle needs some type of extended off line repair or if downstream workload level is affected (ie, too many manual trans in a row, too many sunroofs in a row, etc). This can be done either via a shunt spur which allows the vehicle to circle/stop in a repair area, or can be as serious as removing the body with a forklift for later reinsertion (in the most dire circumstances).
The chassis with it's assorted major components (frame, engine trans) are started at this time. Keep in mind these will also have to be coordinated with the same GA sequence vehicle being stamped with the same VIN as the body making its way though the other half of the process. Nothing random or spontaneous happens here, because there is too much risk at stake with repect to getting any one of these converging body/chassis builds out of sequence.
I’ve attached a chart below with fictional data in an attempt to highlight this. So you can see it might be impossible to confirm that vehicle 123456 came immediately before vehicle 123457 (unless you were there), but we can usually pretty safely say that vehicle 123456 came before vehicle 125678.
However, what I have described above is true only within a specific plant. Each plant is doing this and incrementing up at its own pace, with no linkage to any other plant, based on line rate, overtime, work stoppages, downtime, etc. So there is no way to compare the VIN build date from any one plant to another (unless you have the actual build date in your database).
So – my interpretation:
If both vehicles were built within the same plant – you are probably right (139514 very likely came before 156538), since you are dealing with the same nameplate (Chevrolet) and therefore are within the same VIN sequence starting point (probably 100001).
If the two vehicles are from different plants – there’s probably no way to know (day wise) which was completed first, at least not without a lot more digging.
K
1979-1986
1986 - 2019
Old 03-08-2015, 09:38 PM   #9
Keith Seymore
Now that that is off my chest:
What makes this guy think he has #2? Somebody told him? Urban legend? Vivid imagination?
Keep in mind there were dozens of development trucks, non-saleable and saleable preproduction units built before any of the production units ever started.
Depending on how serious you are, you could send the VIN(s) to the GM Heritage Center archive and order the specific vehicle invoices for those two trucks.
The invoice will have the actual build date on it and there will be no room for any debate.
K
1979-1986
1986 - 2019
Old 03-10-2015, 01:53 AM   #10
c10sport
c10sport's Avatar
K
K
You've confirmed my suspicions, sir. Thank you. The 454SS was only built at the Fort Wayne plant and only available as a Chevrolet so both VINs start with 1GCDC14N*LZ.
Apparently his dad bought two 1990 454SS's, parked them both - one has 3.8 miles, one has 7 miles - and his dad wanted one of the first SS's made so he called so-and-so at GM and was told he got the second one ever made (156538) when it comes in. I call BS myself, by the VIN. It was built on the 18th of October. I have 1238 other 454SS's built before his.
Jay
Old 03-08-2015, 10:38 PM   #11
Hiluxxulih
Hiluxxulih's Avatar
Has there ever been a truck come off the line that was so messed up it had to be junked , because it was dropped or such a strange event happened that it was not repairable ? When I was in high school the auto shop was given a new Chevy truck that was said to have a bent frame , shipping damage maybe , sweet truck sad that it never had a chance , another thing I remember seeing years ago is a train derailed in the shipping yard and destroyed a bunch of GM trucks , the pictures were painful to see .
Old 03-09-2015, 06:34 AM   #12
D13
D13's Avatar
It was not uncommon for plants to donate vehicles. The Lansing MI factories provided a number of bodies used for weld test or set-up to the local schools and colleges. Complete vehicles were uncommon but not unheard of.
Worst one I ever saw was a top of the line Cadillac that missed a tranfer and fell in a pit on one side. Big fork truck drove over and speared it thru the doors and lifted it out, totalling it. As a new hire I asked why they hadn't take care and lifted it out gently. it was pointed out that the sticker on the car was less than the cost of holding up the line for 6 minutes. After that the plant was losing money.
On the other side of the SPID thing, I have an ex-Ryder truck that has 3 full SPID's of content. I haven't found the SPID on my road commission truck - I suspect the only options are the paint color, since it has 250, 3OTT, manual brakes, and maunal everything else.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-09-2015, 07:45 AM   #13
Keith Seymore
Yep. D13's story is pretty representative.
I've seen bodies fall out of the clamshell at body drop; automated welding equipment in the body shop can wad up a pickup cab like aluminum foil.
K
1979-1986
1986 - 2019
Old 03-08-2015, 10:59 PM   #14
undertaker72
undertaker72's Avatar
heres a couple longhorn man posted on another spid post , these are pretty sparse outfits see post #10
http://67-72chevytrucks.com/vboard/s...ighlight=spids
it is fun to see all the options that could be bought back then , not now , you take it or move on
undertaker72 is offline   Reply With Quote
Old 03-08-2015, 11:39 PM   #15
Oregoon
Roadside Rebuilder
Oregoon's Avatar
My '74 GMC LWB has a 250, 3 OTT, no exterior tirm, no folding seat, no power steering or brakes, 2wd, white bumpers, poverty caps, etc... I'll snap a pic of the SPID if you want.
It had 90K original when I bought it. 93K now. Upgraded my ignition to an HEI, otherwise, it's bone stock and in good shape. It's my daily though, and use it for it's original working purpose.
Oregoon is offline   Reply With Quote
Old 03-09-2015, 08:51 PM   #16
Hiluxxulih
Hiluxxulih's Avatar
Neat assembly line stories .
Old 03-09-2015, 09:45 PM   #17
russgt
russgt's Avatar
I put a full floor pan in a 70 c10 cab for a friend, it was a stepside, 250, 3 on the tree truck. The spid had 2 options, positraction and auxilary springs.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 03-09-2015, 09:52 PM   #18
Motherfrog402
Motherfrog402's Avatar
Mine sure looks like a plain Jane but the SPID has a few options.
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
1972 C10 Suburban - SOLD
White/Medium Spruce Metallic/White
Avocado Highlander Pkg
402/TH400
3.08:1 open
Motherfrog402 is offline   Reply With Quote
Old 03-11-2015, 05:11 PM   #19
Bigstevex4
Bigstevex4's Avatar
No A/C P/S P/B 4 speed volt meter heavy rear springs but some stuff listed as standard. Severial times the tires that were tiny 195s
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 03-12-2015, 08:10 AM   #20
Keith Seymore
Tires are released as:
Xxx = Front
Yxx = Rear
Zxx = Spare
That way the purchaser could specifiy different tires on the rear than on the front (like snow tires, for example).
K
1979-1986
1986 - 2019
Old 03-13-2015, 08:15 AM   #21
Motherfrog402
Here's a better view of mine....used the uncropped pic the 1st time. Keith, if the only tire code is ZTC, like mine, safe assumption that all five tires are the same size?
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
402/TH400
3.08:1 open
