Old 03-09-2015, 01:30 AM   #1
73FrankenTruck
73 GMC 2500 Hydroboost/locked brakes after hose replacement
So as I'm cracking into this new project, I've hit a stop that I cannot get around:
History: 73 GMC 2500, 454. Converted to 1-ton dually. truck arrived to me with zero coolant. Replaced heater core, thermostat, all coolant related hoses, flushed coolant system. Went for test drive. Filled up gas tank. Truck drove, turned, and stopped fine. As soon as I (parallel) parked it, saw smoke from under hood. Driver side inner fender had fresh fluid on it. Upon further inspection, the hose from hydroboost booster to the steering box had a pin hole leak.
What I did/what happened: replaced aformentioned hose. Topped off power steering fluid. Started truck, turned lock-to-lock about 40 times while repeatedly pushing brake pedal. Fluid level was same. Put in gear...brakes are locked up. I tried the lock-to-lock deal again, same result. I've researched threads on here, but what i've read always seems to involve replacing the booster. I just swapped a hose. Everything seemed to be working fine.
Any ideas? Am I not doing something correctly? Thank you for any insight.
-C
73FrankenTruck is offline   Reply With Quote
Old 03-09-2015, 12:49 PM   #2
v30crewcab
v30crewcab's Avatar
Re: 73 GMC 2500 Hydroboost/locked brakes after hose replacement
did you have the wheels off the ground while turning them? and you need to do this with the engine off. don't need to push the brakes while turning. bleed all the air out of the power steering,and the hydro will bleed itself.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-09-2015, 06:43 PM   #3
73FrankenTruck
No, I did not have the wheels off the ground while doing it. So put it on jack stands, and turn wheel lock-to-lock with engine off? Same deal, about 30-40 times lock-to-lock? What does lifting tires off ground do?
Old 03-10-2015, 04:52 AM   #4
cerial
cerial's Avatar
Bleed your breaks.
I am guessing you have a collapsed rubber line. It is a common thing on our hydro boost trucks. I have had 3 right front "soft" lines go bad on various trucks over the years which caused the break to lock up for around a hour or more until the line opened back up. It only happens when you use the breaks a lot or push them hard. I could see you driving it normal then pushing on the breaks many times parking.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 03-10-2015, 06:27 PM   #5
v30crewcab
v30crewcab's Avatar
you have to do it with the wheels off the ground, and the engine not running, to get fluid with no air in it moving thru. if its running it gets all foamed up and pumps air everywhere, and doesn't bleed out correctly. with the wheels on the ground it can actually kill the ps pump. with it off the ps box pushes the fluid back and forth and works the air out.
71 longbed 5.3 4l80
Old 03-30-2015, 11:19 AM   #6
73FrankenTruck
UPDATE:
So I finally got around to this. Put the truck up on jack stands, went through the bleeding process. Before I set it down, I noticed I could spin the passenger front tire, but not the driver side. I cracked the bleeder valves, and it seemed to help, but I think I was just delirious from frustration. The driver side caliper would not budge.
I'm wondering if I botched it up pumping the brakes repeatedly while thinking I was bleeding correctly. Regardless, I replaced the calipers and pads. I went to replace the rubber brake lines since that seemed to be a recurring piece of advice. Nothing from the parts store would match up (not my first headache in obtaining parts for this mismatched build). I ended up getting some made ($25 for both) to match the ones I took off.
Everything seemed to be great. Truck moved, ran, and stopped. I noticed the next morning that as soon as I started the truck, the pedal was HARD and I had no power steering for about 3 seconds...then everything was fine. As I drove, the pedal would have a ton of travel, really soft. If you pumped the brakes, it would be normal again. The only thing I could think was I had fried the power steering pump (again, while I thought I was bleeding correctly with truck on ground). I rolled the dice at the parts store without taking my old pump in. Of course it wouldnt be the right pump. Back to match it up. With minimal automotive knowledge, this is fast becoming the most frustrating part. Pump replaced, did both belts while I was at it. Rebled power steering again.
EVERYTHING WORKS.
I know these are simple tasks for most everyone here, but I cant even begin to explain the relief I feel now. Now onto fixing all the other BS that I have no idea where to begin with. Thanks for everyone's advice!
