Old 03-09-2015, 08:07 PM   #1
Droach1977
LS swap fuel system
I have a 1983 c10 that I'm putting a 99 LQ4 6.0 in. I've got a tank and sending unit from a 87, and a fuel pump for a 98. The fuel pump has two hoses with it. I know the the 3/8 line is the supply but what is the small one it's maybe 1/8? Do I leave the line off or put it on somewhere?
Droach1977 is offline   Reply With Quote
Old 03-10-2015, 10:17 AM   #2
mattcrp1
mattcrp1's Avatar
Re: LS swap fuel system
It sound like that 1/4 is the vapor line. I used the 87 sender and I had pressure and return as well as the vapor line. Look in my ls swap link I have the pic of my 87 tank set up going into my 76 that may help.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-11-2015, 07:15 AM   #3
Droach1977
I was thinking it was the vent line but the sending unit I've got doesn't have a spot for it. The sending units vent line is made different.
Old 03-11-2015, 08:11 AM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
How about a picture? If its an 87 TBI sending unit, it will have 3 pipes. Supply, return and vapor vent.
FG05M (driver) and FG05N (passenger) for spectra premium brand parts.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 03-11-2015, 10:12 AM   #5
Droach1977
yeah that's how the top of mine looks also, the issue is the underside. The in tank pump has two lines I know the one is supply but there is also a small line about 1/8". that's the one that I don't have a connection point for on the sending unit. can't get pictures to load, will try again later
Old 03-11-2015, 01:41 PM   #6
Jonboy
Slots go on anything!
You will most likely need to run a new return line. The feed is 3/8, return is 5/16, and vapor is 1/4. You could hook the vent to the smaller line, or run a vapor vent at the top also. The run is relatively small and straight; running new hard lines is pretty easy.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-11-2015, 02:03 PM   #7
mattcrp1
mattcrp1's Avatar
is this what yours looks like? Its an '87 sender with a fuel pump, only one line out of pump.
IG mattcrp1
Old 03-11-2015, 02:04 PM   #8
mattcrp1
mattcrp1's Avatar
Look on the first page of my LS swap link I have a few more pics of my fuel system.
IG mattcrp1
Old 03-11-2015, 09:30 PM   #9
Droach1977
Not sure if these will help but this is what I have
Old 03-11-2015, 09:36 PM   #10
Droach1977
One more pic
Old 03-11-2015, 09:40 PM   #11
Droach1977
Last one. Thanks for the help
Old 03-12-2015, 10:00 AM   #12
mattcrp1
mattcrp1's Avatar
I know see what you mean. I think that the extra hose is part of the '98 set up and may be the source of confusion. I would guess that the little hose is some sort of return line that the '98 set up uses.
My pump is out of a recalled ford product that was new and being thrown out. The 'goldish' piece on the sender body looks to me like a vapor separator of some sort.
IG mattcrp1
