Old 03-10-2015, 08:38 PM   #1
aod92
aod92's Avatar
Doing body work off the frame?
Hey guys. I took the cab off the frame of my truck and I'm replacing rockers and cab corners. Am I gonna run into trouble down the road when I bolt this thing back to the frame? Im just hoping everything stays square. Any of you guys do it this way?
aod92 is offline   Reply With Quote
Old 03-10-2015, 08:45 PM   #2
Kennuck
Kennuck's Avatar
Re: Doing body work off the frame?
I built a stand for mine that locates the original body mounts in their original location. New inner and outer rockers and cab corner installed. It's back on the frame now and the doors and fenders all line up no problems.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 03-10-2015, 09:04 PM   #3
aod92
aod92's Avatar
Did you bolt it to the stand?
Old 03-10-2015, 09:10 PM   #4
Kennuck
Kennuck's Avatar
Yes bolted it to the stand. Used new body mounts and torqued them down. The stand held the body in place very well. My body mount cross members were in good shape and didn't need any work.
1970 Short Wide
Vintage Air
Old 03-10-2015, 09:13 PM   #5
aod92
aod92's Avatar
Great idea just wish I would have though to do it prior to cutting....lol Mine is sitting on jack stands and seems square but we'll see. I only cut one side at a time so that should help.
Old 03-10-2015, 09:13 PM   #6
Kennuck
Kennuck's Avatar
Here is a shot of the body back on the frame.
1970 Short Wide
Vintage Air
Old 03-10-2015, 09:17 PM   #7
Kennuck
Kennuck's Avatar
Hahaha I did the same thing cut the drivers side inner and outer rocker off and then decided to put it on a stand. I built the stand and then verified the mounting holes measured out the same as the mounting holes on the frame. It was pretty solid even with them cut out. Worked out good.
1970 Short Wide
Vintage Air
Old 03-10-2015, 09:18 PM   #8
Kennuck
Kennuck's Avatar
Too bad you're not closer, you could borrow the stand.
1970 Short Wide
Vintage Air
Old 03-10-2015, 09:19 PM   #9
aod92
aod92's Avatar
Thanks man....you're way to far lol
Old 03-10-2015, 09:28 PM   #10
67ctener
67ctener's Avatar
I would highly recommend not doing body work off the grame. Gap all your metal how you want then start working on it. I've seen too many builds with BAD gaps and it drives me nuts, it can be avoided
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 03-10-2015, 10:21 PM   #11
aod92
aod92's Avatar
I agree bad gaps drive me nuts too. I mad a bad decision and already did some cutting and welding while it was of the frame. I would bolt it up to the frame now but it's sitting on the garage floor bare freshly powder coated.
