Old 03-11-2015, 06:48 PM   #1
Mr.Hyde
gas tank relocation
So I'm gonna be that guy...I used the search button and not sure if it is me but I could not find too much that was relevant. I just tried to order a gas tank relocation kit from through a local place I believe they are just an LMC middle man and in Canada LMC is not practical, so here I am. I need to figure out what I can use in place of the blazer tank. i know i would prefer to go either the bed fill or the license plate fill style. This is for a 1968 lwb if that makes a difference at all... can some one give me a hand with this?
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 03-11-2015, 07:09 PM   #2
69-72
69-72's Avatar
Re: gas tank relocation
Did you try Walker? Most of the reproduction parts are the same no matter who sells them. Blazer tank is going to be the best option. To fill you could go through the side marker and hinge it.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 03-11-2015, 07:35 PM   #3
Mr.Hyde
I haven't been in maybe 6 months I will probably give him a call tomorrow only one I was able to find was the side fill and I'm worried that won't work for bed fill. Finished all the metal work don't want to have to jump back into cutting things up again.
Old 03-12-2015, 09:58 AM   #4
Mr.Hyde
Anyone else want to chime in on this?
Old 03-12-2015, 07:06 PM   #5
Mapearso
I used a 69 camaro tank. I wanted fill behind license plate.
Mapearso is offline   Reply With Quote
Old 03-12-2015, 07:35 PM   #6
Rod Run
Rod Run's Avatar
Do you know if it would still work with a rollpan? Or do you need the extra room that the bumper gives you?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-12-2015, 11:41 PM   #7
MAC71
MAC71's Avatar
1988 blazer 31 gal tank. There is also a 25 gal tank
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 03-13-2015, 12:02 AM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Early Classic Enterprises sells a stainless steel tank ( and yes its a little pricey ) and you can order it with a top or side fill. Living in Winnipeg I'm sure you could have shipped to Emerson ND and pick it up there.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-22-2015, 02:27 PM   #9
Mapearso
depends if the roll pan is indented for the lic plate?
Old 03-23-2015, 10:50 PM   #10
Rod Run
Rod Run's Avatar
so it won't fit with an indented, flip down plate location?
Old 03-12-2015, 11:19 AM   #11
engineer_gregh
engineer_gregh's Avatar
This is a good thread.
http://67-72chevytrucks.com/vboard/s...=chevelle+tank
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 03-13-2015, 10:37 AM   #12
rthomas
I'd like to have the 69 Camaro tank that's behind license plate, but can you still install a trailer hitch?
rthomas is offline   Reply With Quote
Old 03-13-2015, 06:42 PM   #13
MAC71
MAC71's Avatar
How about having the filler behind the tail light? Use a biger better fitting fuel tank and it's safer and a trailer hitch or even a hidden hitch will work.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-13-2015, 07:02 PM   #14
DarkFlounder
I'm gonna try to follow DaveMotoHead's lead (here) and put in a 41gal Suburban tank behind the axle with the filler inside the bed similar to this.
I'll be replacing the bed sometime this summer, figure it'd be easier to fit in the new tank, fuel lines and exhaust then.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline   Reply With Quote
Old 03-22-2015, 04:21 AM   #15
MAC71
MAC71's Avatar
Here is a different photo of my tank
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-22-2015, 09:25 AM   #16
Money_pit
Money_pit's Avatar
I'm gonna end up using a Boyd's custom tank . They make a tank and mounting kit and its aluminium I think I found them Just google Boyd's welding
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 03-22-2015, 09:58 AM   #17
MAC71
MAC71's Avatar
I looked at Boyd's tanks also but decided on a gm tank as it was $89. Aluminum is cool but I was worried if it hits somthing it will crack as a friend of mine found out. Also I would like more than 19 gal for my truck and the 88 and newer gm tanks are fuel injection tanks. Just trying to get some options out there for people. If the truck is a show truck and not a driver than the Boyds tank is a good option.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 03-22-2015, 03:56 PM   #18
racerface
I meet a guy at the Columbus Oh. Good Guys show had a 69 LWB with a nice rake, I think it was 4 in. drop in front and 2 or 3 in. in back with a rear fill Suburb tank with a hitch. did not ask how many gallons the tank held. His only real complaint was fueling with trailer in tow.
Racerface
Wellington, Ohio Freedom Isn't Free!
GO BUCKEYES!!!
Toys: 68 C-30 327-400turbo
68 C-30 Open Road Camper 327-400turbo
81 GMC Sierra 1500 250-350turbo Long Bed
83 K-10 4X4 Scottsdale
racerface is offline   Reply With Quote
Old 03-23-2015, 07:15 PM   #19
57larry
I'm going with the Camaro tank, looks like a good set up
57larry is offline   Reply With Quote
Old 03-23-2015, 09:24 PM   #20
vanislegmc
I am restoring a 1972 GMC 4x4. I purchased my tank from KMS tools, they have a Web site and carried both side fill and bed fill tanks for GMC
vanislegmc is offline   Reply With Quote
