03-12-2015, 12:08 PM | #1 |
Help with rear end identification....Eaton HO72?
I did some research and was wondering if I am correct about this 1969 dually rear end being an Eaton HO72. They say the difference between the HO72 and HO52 is the load bolt at the front of the unit which looks like a some type of adjusting nut.
It is in what is left of his C-30 cab/chassis truck, 350/th400. Thanks for any help. |
03-12-2015, 04:27 PM | #2 |
Re: Help with rear end identification....Eaton HO72?
Sure looks like a H072. But load bolts were used on both H052 and H072 axles. Up on the top flange face, the axle code will be stamped in. That would verify original application and ratio.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-12-2015, 05:22 PM | #3 |
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
03-12-2015, 07:53 PM | #4 |
I thought the difference between the two was in the spider gears?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
03-12-2015, 09:48 PM | #5 |
Get the code off the axle carrier then decide if it will work for you.
My guess is its a 4.57 They are very rugged axles and generally don't need a lot of parts.
03-13-2015, 09:52 AM | #6 |
To keep this simple, if it's a dual wheel rear in a C/30 it is most definitely an HO72.
