Old 03-12-2015, 01:58 PM   #1
canadian_diesel1964
1963 c10 heater questions
Hey guys got the truck home yesterday and looked at the heater core which was by passed and on the floor...I went to order a new one and found that maybe some stuff was missing? Is there a box that the core goes into? Here's a couple pics....thanx
canadian_diesel1964 is offline   Reply With Quote
Old 03-12-2015, 02:00 PM   #2
canadian_diesel1964
Re: 1963 c10 heater questions
Heater
Old 03-12-2015, 02:11 PM   #3
canadian_diesel1964
Looks like I'm missing the box that holds the core itself?
Old 03-12-2015, 03:15 PM   #4
bonacker
The heater core goes under the hood on the firewall, passenger side. There should be a larger box it goes inside of. Search on this forum for pictures. You didn't say what type of heater: Thrift Air, Deluxe, etc. as there are differences. Hope this helps.
bonacker is offline   Reply With Quote
Old 03-12-2015, 03:29 PM   #5
canadian_diesel1964
this one has the fan motor inside so its a recirculation heater...sure looks like the core mounts inside as there are 2 holes to allow the hoses to attach to the core..
Old 03-12-2015, 03:38 PM   #6
Slow Build
Slow Build's Avatar
This is what is supposed to look like.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-12-2015, 04:02 PM   #7
CdM
CdM's Avatar
here ya go. You can see where the heater core goes just by the position of the hose's in the box.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 03-12-2015, 03:57 PM   #8
CdM
CdM's Avatar
my 64 is all box mounted under the hood. Ill go grab a pic for you.
Old 03-12-2015, 04:30 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Your missing the plenum on you heater that retains the heater core. CdM picture above is incorrect for your application, he is showing a deluxe heater as you have the recirculating type like Slow Build picture.
Only one pictures in the shop manual for recirculating type heater in section 13 of the American version following the Air Conditioning section.
The heater cores differ as well. Yours does not have the flow control valve as the engine compartment firewall mounted model.
Old 03-12-2015, 05:02 PM   #10
verdell
verdell's Avatar
I'm with "Slow Build" on this one. Looks like your heater core is housed inside the cab on the passenger side. Same set up in my '60.
verdell is offline   Reply With Quote
Old 03-12-2015, 06:23 PM   #11
canadian_diesel1964
Looks like you guys are on the money again!! I'm missing the cradle or plenum .. I'll check the local used place for one...thank you
Old 03-12-2015, 06:19 PM   #12
Greg63
Enjoy your truck
Greg63's Avatar
I had mine apart last summer. There is a "cradle" with two straps that holds the core within the heater housing. It is slightly larger than the core, is open on all sides to allow airflow through it, and mounts to the firewall side of the housing (which allows the core pipes to stick through the firewall.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 03-13-2015, 12:09 PM   #13
bonacker
Didn't know about the core mounting inside. Learn something everyday!
Old 03-15-2015, 08:56 AM   #14
canadian_diesel1964
Hey guys does anyone know a part number for a heater core that goes on this recirc heater? ...thanks
Old 03-29-2015, 12:21 PM   #15
jtrichard
I am also looking for the same core
jtrichard is offline   Reply With Quote
Old 03-29-2015, 12:36 PM   #16
jtrichard
DIESEL 64 I found it Amazon.com: Spectra Premium 94477 Heater Core:... Amazon.com: Spectra Premium 94477 Heater Core:...also here http://www.oreillyauto.com/site/c/de...2709&ppt=C0331
also here is what the parts look like that you are missing http://www.ebay.com/itm/1960-61-62-6...15f28b&vxp=mtr
Old 03-29-2015, 02:22 PM   #17
canadian_diesel1964
Hey thanx man I ordered one from LMC
Old 05-27-2015, 09:46 PM   #18
Crazy Rusty
Crazy Rusty's Avatar
Question Re: 1963 c10 heater questions
I just bought a recirculating heater core from LMC and its no where near the same, the parts where the straps are supposed to go around are much too small. Did yours fit properly?
Crazy Rusty is offline   Reply With Quote
Old 03-29-2015, 02:26 PM   #19
Trap62
Trap62's Avatar
Here are some shots I took of my heater unit before refurbishing it. Different angles on how the core fits into the unit. Hope they help -- Cheers!
Trap62 is offline   Reply With Quote
Old 03-29-2015, 03:48 PM   #20
canadian_diesel1964
That helps a lot thank you ...I was able to obtain the box locally with the retaining straps..and man that's a great deal on that core!!
Old 03-31-2015, 11:02 AM   #21
canadian_diesel1964
Just though I'd report back with how the heater core fits for the recirculating type heater ...I've shown the straps and the box...thanks for all your help...and also here's a pic of my ride today..
Old 03-31-2015, 11:03 AM   #22
canadian_diesel1964
Straps
Old 03-31-2015, 11:04 AM   #23
canadian_diesel1964
