Old 03-14-2015, 01:02 AM   #1
1972BlueC20
1972BlueC20's Avatar
this doesnt make sense
Ok so I been trying to resolve an off idle / off cruise bog or hesitation issue for weeks now.
I've covered all the bases before digging into the carb. You can read all that I've done and checked before delving into my carb HERE :
http://67-72chevytrucks.com/vboard/s...d.php?t=661895
I'm dealing with a Holley street avenger 670
So I was pretty certain I needed to increase my squirter size up 3-5 sizes. I read online that my carb should've had a size .031 squirter in it from the factory. So I ordered a tube style .035 and installed it. I now have horrible throttle response. So I looked closely at the squirter that I had just pulled out and it was marked 42!!!
How on earth did my carb have a .042 squirted in it from the factory??
So now I'm confused, do I go up to .045 + ?
It doesn't seem right that a stock GM crate engine (part # 19210008) would need such a big squirter to run right.
What do you guys think?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 03-14-2015, 03:02 AM   #2
nzc10
nzc10's Avatar
Re: this doesnt make sense
Hey there i was having a similar problem with my 350 even with new carb, fuel pump and manifold stalling at lights and hesitate a cheap way to see if you are starving of fuel is fit a clear in line plastic fuel filter and when it stalls check for gas in it mine was emptying out so i knew i had a fuel supply issue checked all my fuel lines found the rubber fuel hose coming out of the cab to the chassis rail was perished it and kinked also was above the muffler which did not help so replaced the fuel hose with some heat insulation around it and that fixed my problem. I know you have said you have replaced the fuel hose but that piece can be easy to miss hope this helps. Good luck!
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
Old 03-14-2015, 07:19 AM   #3
REEDS 72
REEDS 72's Avatar
If your vacuum advance hose is connected to the ported line coming out of the carburetor plug that one and change it to the manifold one that's the one next to ware the pcv plugs in in front and at the bace of the carb. Try that and see how it runs if you have allredy done this then ok I did not read the whole thread hope this helps.
REEDS 72 is offline   Reply With Quote
Old 03-14-2015, 10:56 AM   #4
69chevy lwb
69chevy lwb's Avatar
I had the same issue my float bowls were to low when the engine was running. But with an electric fuel pump they always looked right when I checked. Set them while running and then set the accelerator pump up again. Mine was adjusted to try and compensate for the lack of fuel so I had to fix that.
69chevy lwb is offline   Reply With Quote
Old 03-14-2015, 11:08 AM   #5
1972BlueC20
That's an idea to try, thanks!!
Old 03-16-2015, 08:29 PM   #6
1972BlueC20
Anybody else heard of a stock Holley 670 street avenger coming with a size .042 squirter ?
Old 03-14-2015, 10:58 AM   #7
1972BlueC20
Thanks guys for the ideas, but I've replaced all the fuel line on the truck and tried with and without vacuum advance as well as trying ported and manifold vacuum.
