03-14-2015, 07:00 PM | #1 |
Heater hoses through bulkhead
Where the heater hoses go through the bulkhead, what have you used to protect the hoses from being cut by the steel & where did you get it? Thanks
yoshi's 49 project |
03-14-2015, 07:23 PM | #2 |
Re: Heater hoses through bulkhead
Are you using an original heater ?
03-14-2015, 07:42 PM | #3 |
No I'm not using the original heater, I've got one from a mini. I do have a large hole about 2" & 4 smaller holes about 1/2" on the driver's side where the brake booster used to be
yoshi's 49 project Last edited by yoshi; 03-14-2015 at 07:52 PM. |
03-14-2015, 10:06 PM | #4 |
sounds to me like you might want to look through the catalogs for Bulkhead Heater fittings.
03-15-2015, 08:55 AM | #5 |
Used bulkhead fitting from t7 design, wanted to have an clean firewall,
mounted the fitting in the inner to outer cowl panel. Hoses thru inner fender. Gr Richard |
03-15-2015, 02:24 PM | #6 |
I used bulkhead fitting to run them into the fenderwell, then grommets thru the inner fender and a support bracket on the wheel side of the inner fender. Was the easiest to get around VA horseshoe hardlines under the dash and battery box.
