Old 03-15-2015, 07:26 AM   #1
Nitis
Nitis's Avatar
67-72 front crossmember VS squarebody
First C10 brought up if it would be possible to put a squarebody front crossmemebr in a 67-72 frame since the squarebody can accomidate a LS engine while the 67-72 needs a custom crossmember
I cant imagine no one has thought of trying this up until now but I havent seen any chatter on it. COuld one fit or be made to fit with some slight modification?
Would seem to be much easier and less expensive than the custom ones being offered
Nitis is offline   Reply With Quote
Old 03-15-2015, 11:16 AM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: 67-72 front crossmember VS squarebody
It's been done before, I know there are a few on here that used them in there big block conversions. It takes a little trimming and drilling, I posted an article from an old 4x4 Power magazine on how to do it but that's been years ago, I'll see if I can find it.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-16-2015, 06:31 PM   #3
First c10
First c10's Avatar
That would be great if you can find the article.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-16-2015, 11:08 PM   #4
BigRed76
BigRed76's Avatar
I haven't found any info to confirm it but I think its safe to say it'll work since you can swap a 73-87 2wd engine crossmember into a 67-72 2wd because the frame rails are the same width at the engine crossmember.
Do the 73-87 guys have to modify their engine crossmembers for LS swaps?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 03-16-2015, 11:21 PM   #5
Nitis
Nitis's Avatar
No they don't. Sometimes a little tight for header which I could care less about but headers are tight in any scenario
Old 03-17-2015, 05:49 PM   #6
7dee2
7dee2's Avatar
Here's one I'm aware of 72 2wd to 4x conversion using the later cross member http://67-72chevytrucks.com/vboard/s...9&postcount=53
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 03-17-2015, 06:10 PM   #7
BigRed76
BigRed76's Avatar
I guess it's safe to say that not all 73-87 4wd trucks have the same engine crossmember because my 76 K10 I had a few years ago had an engine crossmember different from the one used in that thread.
Zach
Old 03-17-2015, 06:49 PM   #8
7dee2
7dee2's Avatar
I would agree but have noticed that they are very similar. I've got one from a 73 K5 and an 84 K30 both look a lot like the 87 K30 used in the example I posted earlier. Differences I noticed had to do with strength extra bolts, tabs, etc but same basic shapes.
Brett
Old 03-17-2015, 07:00 PM   #9
Nitis
Nitis's Avatar
Big block vs small block?
Old 03-18-2015, 01:17 AM   #10
Nitis
Nitis's Avatar
So looking at your picture it makes sense why the LS won't work in the 67-72 k series
Your crossmemeber is basically straight and perfectly horizontal as ours are more "u" shaped and sits farther back closer to the larger part of the oil pan
So in my uneducated non mechanical opinion this is a viable option. But for the cost of $400 for a dirty dingo is it worth the headache of customizing?
Also in looking at my 72 k10 my crossmember appears to be bolted I. As opposed to riveted does this sound correct?
Old 03-19-2015, 05:39 PM   #11
BLAZERMAN
BLAZERMAN's Avatar
Sorry guys I went back thru the archives and couldn't find where I had posted that article so I found the original magazine and scanned it again.
Hope this helps.
Old 03-19-2015, 09:02 PM   #12
BigRed76
BigRed76's Avatar
Hope this helps.
Thank you for finding that
Zach
Old 03-20-2015, 01:19 AM   #13
First c10
First c10's Avatar
Thank you for the info......I think I am going to try this with an LS build.
GO GO!!!
Old 03-20-2015, 01:39 AM   #14
Nitis
Nitis's Avatar
Yeah buddy thanks for jumping on the gernade!
Old 04-05-2015, 11:16 PM   #15
First c10
First c10's Avatar
This is he close up of the stock 67-72 engine crossmember and a 73 up square body
GO GO!!!
Old 04-05-2015, 11:22 PM   #16
First c10
First c10's Avatar
This is what will needed to cut because the 91 burb frame that this came from. It is 5-1/2" and the k20 frame I am using is 5".
The motor mount stand is upside down and bolted to the table so I can cut it tomorrow.
GO GO!!!
Old 04-06-2015, 12:36 PM   #17
7dee2
7dee2's Avatar
Looks pretty slick, great info!! I'm sure this will make the LS (or a BB) swap go easy.
Brett
Old 04-11-2015, 12:11 PM   #18
PortalAxls
PortalAxls's Avatar
Here are some pictures of the crossmember that was in my 67 GMC with the 305 V6. Anyone know if this is the stock crossmember, or a 73-87?
67 GMC K2500. 305D V6, 4 spd, rotted wood bed, and lots of rust!!
WTB: Eaton HO 4:10 or 4:11 tapered beaing gearset, or complete 3rd of either style bearing in the 4:10 ratio
PortalAxls is offline   Reply With Quote
Old 04-11-2015, 12:14 PM   #19
Nitis
Nitis's Avatar
well to my uneducated eyes it surely looks different than the V8 crossmembers of that vintage
First?
Old 04-11-2015, 02:02 PM   #20
First c10
First c10's Avatar
It deffenently is different than the square body v8 cross member. In my earlier picture you can see the stock 67-72 4wd crossmember (black)and the square body( in primer) on top of it. My frame has the bolt holes where your v6 crossmember is bolted. So it maybe a stock v6 crossmember. I am not familiar with the v6 setups. Hopefully someone can chime in. The v6 cross member if stock looks farther forward then my stock one. Below is not a very good picture but you can see the holes in my frame that would accept your v6 crossmember(I think)
GO GO!!!
Old 04-11-2015, 02:12 PM   #21
First c10
First c10's Avatar
Thought I would update this thread a little. I had to cut down the motor mount perches as the sonar frame was 1/2" thicker. So I cut it down and added a piece of 1/4" flat stock. Welded it up. I will post a few more picture.
GO GO!!!
Old 04-11-2015, 02:14 PM   #22
First c10
First c10's Avatar
Cut down.
GO GO!!!
Old 04-11-2015, 02:16 PM   #23
First c10
First c10's Avatar
Ready to clean up with the sanding disc and check fitment
GO GO!!!
Old 04-11-2015, 02:17 PM   #24
Nitis
Nitis's Avatar
Not that they are easy to come by but makes a guy wonder if the V6 crossmember would hold an LS. If I recall the V6 was only in GMC?
Old 04-11-2015, 02:28 PM   #25
First c10
First c10's Avatar
You know now that I think about it. My grandfather had a old gmc with a v6. And he used to say how mean it was. It was when I was very small. I think any crossmember would hold any motor. The crossmembers just hold the frame together. Not support the engine. Well for me and my way of thinking anyways.
Good stuff.
So that crossmember would only be in 4x4 gmc v6??? Probably not to many compared to the other configurations
GO GO!!!
