03-15-2015, 10:51 AM | #1 |
Cab Corner Moldings
What do you all think? I cleaned all the paint off, should I just repaint the bow-tie black or gold? Should I just leave it the way it is or re-paint the whole emblem again? I did try to paint the inside of the square gold, with touch-up paint, but that didn't turn out very good. It would probably look better spray painting it, but that would be alot of tedious masking.
03-15-2015, 10:59 AM | #2 |
Re: Cab Corner Moldings
I plan to paint mine like the top picture. CAT yellow and gloss black.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
03-15-2015, 01:23 PM | #3 |
Well I painted the Bow tie black, thinking I'll leave it them just the way they are.
03-15-2015, 03:52 PM | #4 |
I like them painted like original and the masking for Chevy cab corners is much easier than the ones for GMCs. It is all about personal preference though.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
03-15-2015, 04:00 PM | #5 |
Get some black fingernail polish.
With the bowtie facing up (and perfectly level) use the little brush to lay on a light coat of the nail polish. No need to get too close to the edges - the polish will flow right up to the border and fill the whole bowtie perfectly. When the first coat is dry, add another coat. Good quality nail polish will last a wicked long time. Looks like your job came out pretty nice anyway. |
03-15-2015, 04:03 PM | #6 |
Already got them painted and back on the truck.
03-15-2015, 05:19 PM | #7 |
I have not attempted removal of this trim on my '85 yet but I will soon.
What is the procedure? |
03-15-2015, 06:21 PM | #8 |
Take the rear corner speaker cover & speaker out, if there's one still there. Reach up into the hole and you'll feel a stud with a speed nut on it. It will be just behind the little bow tie emblem. Back the nut off and then you can remove the molding from outside the truck.
03-15-2015, 06:21 PM | #9 |
id like to add that trim to mine! i dont have any holes there though. any one know if lmc ones have the 3m on them already?
*^MY BUILD STORY^* |
03-15-2015, 06:39 PM | #10 | |
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=122 I suppose if you found thick enough 3M tape, that would work. Here's what the back looks like, but this one doesn't have the stud clip on it, those are separate. And also, the ones from LMC are plain, they don't have the emblem. Last edited by TKCR; 03-15-2015 at 06:50 PM. Reason: added a link |
03-15-2015, 06:54 PM | #11 |
Thank you for that explanation, I appreciate it.
06-04-2015, 03:42 AM | #12 |
Can you post the dimensions of the emblems? When I order my trim I hope it wont have them. I bought some small aluminum Autobot Transformer emblems and I want to put them on the trim instead. Yes Im sort of a geek.
06-04-2015, 11:02 AM | #13 |
1 3/4" x 1 3/4" square. The moldings that you get from LMC will not have the emblem on there, they are just plain. So you'll be able to add your own emblems
06-04-2015, 04:47 PM | #14 |
Can you explain what you used and how you cleaned the trim up? It looks great all 3 ways to me!
06-04-2015, 09:04 PM | #15 |
06-04-2015, 04:53 PM | #16 |
Frequent Flyer
Here's what I did with mine...
06-04-2015, 09:06 PM | #17 | |
06-04-2015, 11:07 PM | #18 | |
Frequent Flyer
It's a slow process to get it all polished out. There are a couple of threads on here about doing it. Posted via Mobile Device |
07-06-2015, 04:49 PM | #19 |
Registered Cruiser
Does anyone happen to have measurements for the cab trim/corner moldings?
I have the yellow cab trim for my 77, but the truck didn't originally include trim or the previous owner removed it... I need the measurements for each of the side pieces (one hole each) and also for the rear trim where it is riveted. I have researched without any luck. Any diagrams available? Thanks, Justin
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
