Old 03-18-2015, 07:18 PM   #1
magicoolbus
magicoolbus's Avatar
Diy spid
Hi folks,
Been spending some time at the PC lately in an effort to come up with my own SPID for my suburban. I was unhappy with what was available and thought I could do it myself. I did a lot of research on the font and as many have discovered, it is no where to be found. So in the modern computer era, I figured there has to be something that is close that would only be discernable to the purist of the hobby. I do believe I was successful and was able to find a font called "Artisan 12" from the dafont.com website.
I uploaded it to my PC and at first tried to make a bit of a template using word, but was very quickly dissatisfied with the results and the effort with the alignment. Switching over to Excel proved much easier, all told, I would say I have about 1.5 hours in the project total.
I ordered a couple of blank SPID's from LMC for about 5 bux each. Next just printed the 'beta' SPID on regular paper and held up to the blank. Made notes where I needed to tweek the alignment and sizing and reprinted. I probably printed about 15 'betas' until I had what I thought was an acceptable template. After each print, I would hold the blank SPID behind the printed page and using a flashlight aligned the columns. A glass coffee table with a light underneath would have been the optimum method I believe. Once I was sold that I was in the ballpark, I used some of the wives double stick 'scrapbook' tape and taped the blank SPID onto a final 'beta' piece of printed paper aligning it as before using the backlight method. Then printed it again with my printer. Being that the ink is not what I would call UV and or waterproof, I plan on covering up the SPID with a clear piece of vinyl.
In looking at numerous SPID examples, I did find some consistent areas to base my template on, in particular the wheel base dimension was always aligned under the second "I" in "IDENTIFICATION" directly above the box. The VIN number 3rd digit was typically under the "S" of SERVICE. I also noted that with very few exceptions the interior color code was on the bottom left column and the exterior paint code on the bottom right. The basic 3 digit RPO's are basically alphabetical, with no real rhyme or reason of left or right column.
Below is a photo of by 'before' and my 'after.' All told, I have about 6 bucks plus time into the project. If interested in my excel file, send me a PM and I will email you the file and you can determine if it may work for you.
I also included another project that I just completed for the Jack Stowage decal. This is not reproduced by any vendors that I am aware of. Let me know what you think.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 03-18-2015, 07:51 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Diy spid
I certainly no expert but the SPID looks good, too good
I meant to ask how the jack storage sticker was coming
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-18-2015, 09:08 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Diy spid
Your SPID & jack decal look great....
I did the '67-'68 pickup one because it is not reproduced so I can appreciate the amount of time you have invested in them....
http://67-72chevytrucks.com/vboard/s...d.php?t=520919
LockDoc
Leon
Old 03-19-2015, 08:48 PM   #4
tedfrk
tedfrk's Avatar
Re: Diy spid
Just wondering what could be done if I don't have the original to go by???
tedfrk is offline   Reply With Quote
Old 03-19-2015, 09:56 PM   #5
magicoolbus
Re: Diy spid
You can create your own, make a list of the factory items that you can determine that you have. Many of us make our 'new' SPID labels with our additional 'factory' items we add, like Tach, Vacuum, Posi, A/C, etc. Lots of resources for RPO codes, but one of the best places is this site SPID label threads. You may get lucky and have a build sheet still lurking under your seat, it will be between the foam and spring. Good Luck.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 03-21-2015, 01:54 AM   #6
rocknss
rocknss's Avatar
Re: Diy spid
Looks real nice!
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 03-21-2015, 09:36 AM   #7
tidmack
Junior Member
Re: Diy spid
This is the best reproduction SPID I've seen. It's almost disappointing to know that I'll have to start finding new ways to determine whether options originally came on a truck, or if it's a true shortbox, etc. Very nice work.
Jeff
tidmack is offline   Reply With Quote
Old 03-22-2015, 09:08 PM   #8
oski6754
oski6754's Avatar
Re: Diy spid
Can't find the blank SPID stickers at LMC. Can you share the link? Many thanks and great work!
Miles
1972 GMC Suburban K15 - Custom Deluxe
oski6754 is offline   Reply With Quote
Old 03-13-2016, 09:39 AM   #9
Re: Diy spid
Jeff
It's been going on for over 25 years that I know of. I bought blank SPIDs from Cheyenne Superman/Gary Terry in the late-80s.
Old 03-22-2015, 09:24 PM   #10
magicoolbus
Re: Diy spid
Here you go:
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=158
P. 158 in their online catalog, part number is 38-0196.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 03-23-2015, 12:26 AM   #11
LockDoc
LockDoc's Avatar
Re: Diy spid
Classic Parts has them also.
http://www.classicparts.com/1967-72-.../#.VQ-UvqrVrTo
They call it an "Option List Decal"
LockDoc
Leon
Old 03-23-2015, 09:26 PM   #12
DWilbur
Re: Diy spid
Very cool I would like to do a custom SPID for my truck.
DWilbur is offline   Reply With Quote
Old 03-12-2016, 11:38 PM   #13
elpound
elpound's Avatar
Re: Diy spid
Size:  42.8 KBI wish I would have seen this post before I had my SPID made up.for my 70 chevy. Could have saved a few bucks. I don't think I could have made it very quickly though.
elpound is offline   Reply With Quote
Old 03-13-2016, 12:13 AM   #14
magicoolbus
Re: Diy spid
That looks fantastic. I am sure it is worth the money you spent!
JB
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 03-13-2016, 07:17 AM   #15
elpound
elpound's Avatar
Re: Diy spid
Thanks! Coming from you, it is a real complement!
Old 03-14-2016, 11:40 AM   #16
pwdcougar
pwdcougar's Avatar
Re: Diy spid
Nice work!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 04-10-2016, 12:31 PM   #17
raggedjim
raggedjim's Avatar
Re: Diy spid
JB, if you send the excel worksheet does the font migrate or do I need to download the font from the site you mentioned?
Great work on this, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 04-10-2016, 01:18 PM   #18
magicoolbus
Re: Diy spid
RG, should be in you inbox.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 04-10-2016, 09:26 PM   #19
raggedjim
raggedjim's Avatar
Re: Diy spid
Thanks, I appreciate it.
Rg
Roger
'70 GMC Jimmy 2wd
Old 06-14-2020, 06:50 PM   #20
lugnut
lugnut's Avatar
Re: Diy spid
Sent you a pm. I'd love to get a copy of your spid sheet. Thanks.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
