Old 03-18-2015, 08:07 PM   #1
88Ironduke
Seal your floor - How I did it
Now that my floor pan is all welded up, painted and sealed I have decided to seal my floor with a sound deadening. So on my beer budget means cool products that are expensive are out.
In an effort to help give a little to the folks here who posted a lot great information and helped me out I'll try to pass on my little bit.I read a bunch of post here about going to Home Depot and Lowes and getting a rubber sticky mat of various flavors. My process was pretty straight forward. Clean the floor and remove grease/debris. The product in question is known to me as "Ice Guard" for your roof and at my Home Depot comes in 6" wide strips at 25 feet long for 18 bucks with tax. Two rolls got my floor sealed up to the gas tank. I may buy some more to wrap the front of the tank but it comes out nice. Not too bad. A warm garage and a something to work the rubber mat into the nooks and crannies is required. I used the butt end of an old screw driver that was pretty smooth. Nuff Said. Thread suck with out pics.
And the result.
I threw down a bit of aluminum foil tape around the foot well areas to help cover any seams that seemed a bit too wide, talking 1/16". This stuff is forgiving but the more time you take laying down the stuff in an orderly fashion the better the end results.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 03-18-2015, 08:39 PM   #2
Norgermish
Norgermish's Avatar
Re: Seal your floor - How I did it
That's pretty cool, I've been looking for beer budget stuff like that. Looks like it'd work for me. Thanks
Norgermish is offline   Reply With Quote
Old 03-18-2015, 08:45 PM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
Nice job...that's going the extra mile on your truck!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 03-18-2015, 08:52 PM   #4
1968aj
I just used a similar product from lowes to do my floor. will you put carpet down next or will you use a padding before the carpet?
1968aj is offline   Reply With Quote
Old 03-18-2015, 09:35 PM   #5
88Ironduke
I have a carpet with padded insulation I picked up here on the forum. I should have added that there were no fumes or off gassing from the product. My rattle cans of primer are far worse in smell. Should make for a decent ride once finished. I can't wait to drive this truck!
Paul
Old 03-18-2015, 09:38 PM   #6
kodiakjoey
I was thinking about using thr same stuff in my c10. Now Im in 110%
kodiakjoey is offline   Reply With Quote
Old 03-18-2015, 10:26 PM   #7
oldertruckfan
I'm going back to a rubber floor mat. I like the durability. I really wonder how well this would hold up under everyday conditions. I'm in if there's someone that's tried it and was successful with it
oldertruckfan is offline   Reply With Quote
Old 03-18-2015, 11:46 PM   #8
Mapearso
This would go UNDER the carpet or the rubber floor mat.
I used something similar on my 66 Skylark. Got it at Home Depot. I think it was called "Frost King" duct insulation. Comes 12" wide by 15' long
Mapearso is offline   Reply With Quote
Old 03-19-2015, 08:06 AM   #9
bean
Can you show pics of the ice guard? Great job
bean is offline   Reply With Quote
Old 03-19-2015, 09:28 AM   #10
Mike C
Mike C's Avatar
The pic of his floor IS the ice guard...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-19-2015, 09:36 AM   #11
brimc
brimc's Avatar
This looks like a great idea. I'm going to give it a try.
Thanks for posting this.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 03-19-2015, 10:12 AM   #12
cooperhw
cooperhw's Avatar
I bought and installed a sound deadener kit from one of the big boys (expensive) for my 67 Chevelle. I was a little short so I also went to the big box store and bought this exact same material. I think there is not that much difference between the two and will use this same type of ice dam product from now on.
Seems fine to me.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-19-2015, 10:30 AM   #13
WarMonger
WarMonger's Avatar
How thick is this stuff? Looks great and I bet it really quiets down a lot of the noise?
WarMonger is offline   Reply With Quote
Old 03-19-2015, 03:50 PM   #14
88Ironduke
I couldn't give you an exact dimension as to the thickness. I'm certain Dynamat or Fatmat or some commercial product are thicker but the cost are not in the budget. I am working a clean nice driver. There is something cool about the Fatmat logo everywhere on the floor but its cost.... eeewww
Thanks for the positive feedback.
Paul
Old 03-19-2015, 01:44 PM   #15
Jimjific
Jimjific's Avatar
I did something similar with my 69 Mustang. I used this stuff first (from Lowes).
http://northlandconstruction.com/pro...-water-shield/
Then I used spray adhesive to attach a layer of this.
http://www.lowes.com/pd_13353-56291-...3D2&facetInfo=
Carpet went on next and it seems to have worked really well.
Jim
Thanks,
Jim - 69 Short Step CST 350 AC/PB/PS
- 69 Short Step 307 Man Column/PS
Jimjific is offline   Reply With Quote
Old 03-19-2015, 02:08 PM   #16
shawno72
C/10 junkie
shawno72's Avatar
Great idea. Thank you.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-19-2015, 06:48 PM   #17
magicoolbus
magicoolbus's Avatar
Same product as Peel and Seal. Orange vs. Blue home centers.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 03-19-2015, 06:55 PM   #18
midnight rambler
midnight rambler's Avatar
i used that product under my seat and fat mat on the floor boards didn't notices any difference in smell or heat transfer.
midnight rambler is offline   Reply With Quote
