Old 03-24-2015, 07:32 PM   #1
Rspaeth
Advice on 700r4 swap
So I'm just starting a body off on my 71 and think i wanna swap the turbo 350 for a 700r4 overdrive tranny. Currently have a tired sbc but think I'll do a 383. I will be using the 205 transfer case that's currently in the blazer.
I'm assuming I'll keep the same motor mounts and have to move the tranny crossmember? Also will the linkage from the turbo 350 work on the 700r4? Lastly, how will the new trans affect the location of the transfer case?
Any info would be greatly appreciated!
Rspaeth is offline   Reply With Quote
Old 03-24-2015, 10:22 PM   #2
Madtrucker
Re: Advice on 700r4 swap
Mine was done by the po, but I just pulled the trans and had it rebuilt. Mine was a sm465 to 700r4 swap though. Stock motor mounts, advance adapter spacer and output shaft and coupler. It looks like the t-case moves back about 3"s which puts the front driveshaft at its limit. The trans pan also needed to be clearanced to make room for the dc/cv joint. A little different but hope it still helps.
1968 k10 lwb-swb stepside
1936 chevy truck
1977 corvette
My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176
1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824
Madtrucker is offline   Reply With Quote
Old 03-24-2015, 11:57 PM   #3
Rspaeth
Great, thanks for the info
