03-29-2015, 04:39 PM | #1 |
clutch pedal options?
So I'm looking to get a 80-87 Chev or gm. I'm looking for truck that is already standard but I may not be able to get one. So I'm wondering what my options are for making a auto a standard. (If I can't find a factory standard)
-could I use the wilwood clutch pedal assembly? Its a single pedal and bolts to the fire wall. Would it work? -wilwood clutch and brake pedal assembly? Its 2 pedals. -or factory clutch and brake pedal assembly from another truck and swapping it in. Very hard to find though. Is it my only option? |
03-29-2015, 07:43 PM | #2 |
Re: clutch pedal options?
I would use the assembly out off a junkyard truck. One of the great thing about GM is there inter changeability,
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
03-30-2015, 02:24 PM | #3 |
definitely go for a gm factory pedal set and go for hydro one 85 and up.(rod ones are tough on knees but to each is own).get the whole deal at a junkyard steering column and pedal set with all the bracket (clutch cylinder brackets)etc.keep the electrical wires connected and cut the wires .there is a lot of 1 ton stretched frame firewood box in junkyards around here most of them were manual . from there you can decide witch transmission you want if you cant find a truck who's already manual.
