stock oil pressure gauge question
anyone know what size and kind of thread on back of stock oil pressure gauge?i'm trying to get fittings to convert to -an fitting to use braided line instead of copper line.thx dan
Re: stock oil pressure gauge question
1/8" npt with 1/8" compression fitting. i think you"ll need some sort of adapter.
The GM oil pressure gauges use a special type of compression fitting where the ferrule is built into the nut.
Weatherhead calls them "threaded sleeve" fittings and their 6100x2 nut will connect 1/8" tubing to the back of the stock gauge. ![]() Edelmann calls them "double compression" fittings and their part number for the nut is 111200. The Everco equivalent is 11A. I don't think anyone makes an adapter to go from the port on the stock gauge directly to AN. |
great,thanks!sounds like i need 1/8''npt to -3-an adapter and i'm good.
posted same time as ray.so it's not 1/8'' npt??
1/8" NPT is pretty common on aftermarket gauges. And I have seen a few stock (mostly mid-70's medium duty truck) oil pressure gauges with NPT threads.
But the fitting I posted above is what I've seen on the vast majority of GM oil pressure gauges. If I remember correctly, they have straight 5/16"-24 threads (like a bolt). The seal is formed by the special tapered end of the nut which acts like a built-in compression ferrule when it's tightened down into the port on the back of the gauge. |
ok thanks ray.so i guess there would not be a fitting to convert to even npt.hhhmmm??
I have all the part #'s to convert to a -an braided line, give me a few minutes to get them out of my build thread.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Ordered the stainless oil pressure gauge / block kit through Summit. Its an Auto Meter kit #3235. This kit is a 4' length, but they have a longer one also.
The hose is -3 AN which is 1/8" inside, so same as the plastic line kits, but looks much better.
![]() Join Date: Oct 2007
Both ends of the hose are female. I see the fitting in the photo that inserts to the back of the gauge, but I don't see another fitting in the photo to screw into the engine block that also has a male end to connect to the hose?
#11 | |
Few pics of the install I did. PO had an existing hole drilled here, so I used that hole, but it widens to 3/4" for the grommet and stainless line to pass through. The kit says to slit the grommet, but I didn't have any issues getting it over the fittings...just take your time and it'll work on.
Cool, thanks!
Couple more pics and the fitting for the back of the gauge
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-30-2015 at 09:23 AM. |
Thanks very much for the info 1963c10!i will order that up today!
#15 |
Just to confirm, the auto meter kit didn't come with the fitting to connect to the pressure gauge, you got a 5/16-24 x 3AN fitting separately correct?
Is this the correct one? Edelbrock 76525 Flare Fitting Adapter, Straight, -3AN x 5/16-24 Stainless
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
#16 |
No problem. I keep all my part numbers just for these reasons.
#17 |
Post 11, 1st pic...it has the plastic cap on it to protect the threads.
Also pictured in the kit on post 10.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-30-2015 at 04:32 PM. |
#18 |
That's correct. The fitting to the gauge was not included in the kit.
#19 |
Summit racing #16150 was the fitting I used.
Heres the link: http://www.summitracing.com/parts/nex-16150
#20 | |
