03-30-2015, 07:17 PM | #1 |
Can you tell if this is a 350 or 305
Casting number 14010207
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
03-30-2015, 07:27 PM | #2 |
Re: Can you tell if this is a 350 or 305
No way to tell. Pull the valve covers and get the numbers off the heads to help you better. Or get the numbers off the pad behind the alternator.
03-30-2015, 07:35 PM | #3 |
Yes there is a way to tell. There is a number underneath the passenger side cylinder head on the flat piece on the block where the water pump attaches. There should be some numbers and a few letters at the end. Those letters are the engine suffix which you can use along with the engine year to research online which engine it is.
03-30-2015, 07:39 PM | #4 |
http://www.nastyz28.com/chevy-engine-code-stampings.php
About two thirds of the way down the page is an index for engine suffixes. If you can find your engine suffix, that will tell you what it is. |
03-30-2015, 07:39 PM | #5 |
According to mortec it's a 350.
http://www.mortec.com/castnum.htm For the suffix code also look here. http://www.nastyz28.com/decode.php |
03-30-2015, 07:42 PM | #6 |
The heads are off of a 350. The 305's had a saddle marking on the ends of the heads. Those look like #624 casting 350 heads. Those are the lighter casting heads. The little triangle shape on the end of the heads tells me that. This is from my memory banks although somewhat depleted over the years, it could be an #882 casting(earlier pre '78) but definitely 350 heads. With the dish in the top of the 305 pistons those heads on a 305 engine would make a fairly low compression engine, I would bet it is a 350
03-30-2015, 07:47 PM | #7 | |
03-30-2015, 10:35 PM | #8 |
Yeah heavy metal you are right about 882's but nothing compared to the #624's. these heads were let's say extremely light comparatively, seems like 90% of which cracked in the center 2 combustion chamber exhaust seats. The 305 heads #450 2 bbl., #416 4 bbl, and small chamber #301 all had the same cracking problem. Anyway, sometimes a chevy motor can be identified (reasonably) by knowing the casting markings on the ends of the heads.
03-30-2015, 07:45 PM | #9 |
It is probably dated between 1978 and 1986
03-30-2015, 07:48 PM | #10 |
03-30-2015, 07:57 PM | #11 |
I was told it is out of a 1982 Chevy truck.
Thanks for all of the info guys, much appreciated.
03-30-2015, 08:40 PM | #12 |
"14010207" casting # shows as 80-85 350 truck.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
