Old 08-28-2003, 08:36 PM   #1
Blue4x4
Blue4x4's Avatar
gaskets for tranfercase????
Does anyony know if a gasket / RTV is required on this transfer case? On the 8 pointed cover that is missing. it was leaking fluid and after taking it apart I found no seal/sealant.
Blue4x4 is offline   Reply With Quote
Old 08-28-2003, 08:45 PM   #2
JimKshortstep4x4
Smile
We have used RTV on the plate and it works very well. You want to be careful not to have excess RTV get inside.
Jim
Old 08-28-2003, 08:52 PM   #3
Class of 69
Class of 69's Avatar
Were there shims under the cover too?? My T 221 leaked bad, and I eliminated the shims, and it still fit tight to the case, so I used RTV sparingly and no more leak.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-28-2003, 11:28 PM   #4
71 fun
RTV
You should have no problem with RTV but keep in mind many of the bolts in your trans case go through to oil and must be sealed. I have seen people change seals when the problem is the leaking bolts.
71 k/20 GMC
79 k/10 GMC
96 k/10 GMC
71 fun is offline   Reply With Quote
Old 08-29-2003, 06:33 PM   #5
Blue4x4
Blue4x4's Avatar
I found no shims under this cover. Thanks for all the help.
