www.73-87chevytrucks.com
![]() Join Date: Dec 1999
73-87chevytrucks.com's Triple Pillar Pods are now available.
73-87chevytrucks.com Triple Pillar pods are now available. We will be shipping these starting next week. I am currently packaging them and have 1000 on hand. This will be a regular production Item, so we will keep these in stock. Right now I have to figure out the demand on these.
You can purchase yours here at this link for $105.95 + $10 shipping to Continental Lower 48 States. Please email us at webmaster@73-87chevytrucks.com for shipping outside of the lower 48 States: http://store.73-87chevytrucks.com/me...y_Code=7387INT This is what comes in the box. Instructions (basically this information on our recommended install procedure), the pod, (3) #6 Stainless trim screws and washers. Note that it is expected that the pods will be painted to match as they ONLY come in one color, gray. ![]() On the back of the pod there are 2 injection "bumps" that will have to be filed off. Note below the top has them, and the bottom does not. These will need to be removed prior to fitting to the pillar. I suggest using a round file to remove it. ![]() Once you have these removed it is recommended that you position it in the vehicle to your liking as far as height. There is a limited amount of height available and you do not want to cover the screw hole as shown below. Mounting this too high will cause it to not seat well on the pillar. ![]() Once you determine where you want them to go you will need to drill pilot holes through the pod and the pillar. The opposite side of the Injection "bumps" is where it is recommended to put these holes. It is recommended that you clamp the pod down over the pillar so when you drill through both it will not move. You can see the points to drill below: ![]() Once the pod is where you want it drill the 2 holes. ![]() For the best optimum fit it is recommended to drill a hole at the top side. This is especially true if you mount it high. You can see the screw at the top back edge here: ![]() Painting/texturing This is left to the purchasers discretion, but this is how we did this. What was needed was a can of Duplicolor bedliner and a can of either SEM or Duplicolor Vinyl and Fabric. ![]() Painting the pillar is just a matter of following the instructions on the can. Make sure you clean the pillar off. If it has been previously dyed used Lacquer thinner, otherwise you can skip straight to dishwashing soap and water. Adding ammonia will help strip off any oil. Once washed, rinse it off and let it completely dry. ![]() For the pillar pod, you want to completely scuff the whole exterior surface. There is the possibility of mold marks, just sand them off. We used a red scotch brite pad. When you are with the surface wash it off and dry it. Now is the time to add the texture. For best results I recommend holding the can of bedliner at least 16" away and spraying and start and stop well after the part. Typically 2 or 3 light coats should give you a good texture. This is up to the purchasers discretion ![]() We sprayed the pod both laying down and hanging up to get an even coat. Once satisfied it was time for the Vinyl spray of your choosing. ![]() ![]() ![]() Here is the original pillar with the triple pod mounted to it installed in the truck. Along with a close up for the texture. ![]() ![]() Note: The pillar pod holes were sized to allow for the smallest 2-1/16" generic gauge we could find. Some might require a bracket so you may want to confirm prior to purchasing. For the Autometer gauges they will require some light sanding to open up the hole. They are very tight fit and ramming one in without sanding will end in it being VERY difficult to remove. For routing the gauge or wiring this will require holes to be drilled per the sender required. Keep in mind how tight a bend you can turn and how you need to get it out. We designed these with enough airspace at the back to allow turns for the typical Autometer gauges. Here are some more pictures of the pods themselves ![]() ![]() ![]() Here is the pod with a boost gauge installed for reference: ![]() ![]() ![]()
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
yeller
Re: 73-87chevytrucks.com's Triple Pillar Pods are now available.
Nice work Chris!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Old Heap Driver
Very nice!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
I know the pieces fit
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work. When I get back on my 76 I may be getting one.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Diggin The SquareLife
2" gauges fit?
I might have to put some money aside for one of these.
1980 chevy c30 6.2L diesel swap here's the build thread http://67-72chevytrucks.com/vboard/s...=1#post7161431 1995 chevy c3500 6.5L diesel 1997 land rover disco I 6.2L diesel swap, MPG rumored at 26-28
bbbc10 sorry, didn't get a notification on this for some reason. This is for 2 1/16" gauges, I made the opening fairly tight. You have to force an autometer in the opening. It was the biggest size.
Thanks for the kind words. Got a lot of time and money in this.. Hope everyone likes it.
Can this be mounted in a truck without the factory plastic trim?
Mike, they mount to the existing pillar in the trucks. I am working on a potential solution for trucks without the a-pillars but currently these require a factory one.
Thanks again Chris for building these. I did a mini review on them:
1982 GMC Crew Cab 4x4 - "River Truck" build thread 1973-1987(91) Chevy/GMC How-To Videos |
arrover, thanks for the review!
yeller
Nice work Arrover!
#15 |
Thanks guys! Chris did a good job on these and I just wanted to give people a different look at them.
#16 |
Chris is their any chance yall will do a complete a pilar pod replacement instasofjust the pod add on piece
#17 |
We are currently looking at that right now. No updates of any kind as this is a complex injection mold.
#18 |
#19 |
Looks likes a blind spot for me but very nice work. Maybe a smaller LED gauge and lower or inline with the pillar. Be good for off road or racing. Sorry but just my 1 cent ,not 2 ,just 1
#20 | |
Compare this to say a GMT800, which has a 5" wide factory pillar, Or compare it to any modern vehicle like my 2006 LJ or wifes 2015 JKU. This is in my daily driver and has been for 5+ years (w/ right at 50K miles) and currently we have sold 700+ of them. They were designed by me to allow full direct view to the gauges from anyone from 5'-4" to 6'-4". The pillar on these trucks are way to thin to allow mounting directly in front of the pillar unless they are almost 6" out/forward and even wider which intrudes with the door seal/door and forward view. below is me driving it with passenger holding the camera by my face simulating looking toward them followed by another picture with me stopped in PowerTour traffic with the phone directly in front of my face where they are not seen
#21 |
How would this be more of a blind spot than any newer truck with a wider A pillar and huge tow mirrors just behind it?
I put one of these on a customer's truck a while ago and he never complained about anything to do with the pod. He was just glad there was something available for these trucks.
#22 |
I like reading this kind of feedback, Thanks Dieselwrencher!
Tags |
73-87, 73-87chevytrucks, roundedline, squarebody, triple pillar pod |
