Did our trucks come with pads between bed and frame?
I took the bed off my truck and there was nothing between the bed and frame.
I see where pads are available at Classic Chevy Truck Parts. Were they installed from the factory? Thanks |
Re: Did our trucks come with pads between bed and frame?
Never mind, found my answer.
The answer is no in case someone else is (or does) research this matter.
Yes, my bad, I should have explained. The Step side beds have the pads, not the fleet sides. The ones you see for sale are for stepsides and are 1/4" thick and would throw your bodylines off bad.
I am going to cut some pads about 1/16" thick out of some material. I think it will help in absorbing sounds. |
In my case, I installed some dense 1/4" thick pads at the rear of the frame rails and use about 3/4" thick rubber snubbers at the front of the frame rails because I have a dump bed conversion and the bed bounces around when driving and makes a lot of noise. The trim lines on the side of the bed does not line up the the corresponding line on the doors and front fenders, so I am leaving all of the trim off to lessen the visual impact.
#6 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#8 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-05-2015 at 07:13 PM. |
yeller
I ran 1/8" thick rubber washers between my bed and frame on my 73 fleetside, the local Ace Hardware has them in all shapes and sizes.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
yeller
Get a washer that is as wide as the frame...so you have more coverage for movement
