Old 04-06-2015, 06:22 AM   #1
ACII
ls1 swap which speedo / tachometer ??
Hy all
after my ls1 swap ( of a 99 camaro) into a chevy pickup 51, i am looking for speedo / tachometer which are working with the the original pcm signal...
Which gauges would recommend ??
Achim
ACII is offline   Reply With Quote
Old 04-06-2015, 08:00 AM   #2
ls1nova71
ls1nova71's Avatar
Re: ls1 swap which speedo / tachometer ??
Pretty much any aftermarket gauges will work. I have been happy with my Autometers.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-06-2015, 11:13 AM   #3
ACII
so far i could check the internet , the signal of the camaro pcm is a
4000 pulse per mile square wave DC signal
so i would say it should fit
here is a link of the parts on ebay
http://www.ebay.com/itm/271492222924...witem=&vxp=mtr
cu
achim
Old 04-06-2015, 10:55 AM   #4
ACII
Thanks for ur response.....
i just go a manual of a ebay seller, the guy is selling gauges which are adaptable.
Below u can see which signal the gauge can handle... !!!
Do u know which signal the camaro pcm is using ? Thanks Achim
Speedo, hall effect sender (logic input, square wave, 12V) 110
Speedo, magnetic sender (analog input, sine wave, 2.1V min.) 111
Speedo, S1 can set to 0 if not working at high speeds 0xx
Speedo, S2 can set to 0 if reading not stable x0x
Tachometer, Ignition coil or “W” terminal (high voltage) 110
Tachometer, magnetic sender (analog input, sine wave, 2.1V min.) 111
Tachometer, multispark tacho output (MSD ignitions, 2.1V min.) 000
Tachometer, S1 can set to 0 if not working in high RPM 0xx
Tachometer, S2 can set to 0 if reading not stable x0x
Old 04-07-2015, 02:08 PM   #5
Iceburgh
Iceburgh's Avatar
I am installing gauges now..... I will say this. I would not use Speedhut. They are a PIA to get in and work with the LS and they are to much $$$ to have this many issues.
In any case you will need Auto Meter part#'s 2277 and 2268 for adapters for oil and water
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 04-07-2015, 02:10 PM   #6
Iceburgh
Iceburgh's Avatar
If you get a speedo that uses GPS they work with anything....simply needs 12v switched power. No hook up required to the PCM
1953 suburban build
Old 04-07-2015, 02:30 PM   #7
Advanced Design
Advanced Design's Avatar
I used Dakota Digital gauges in my 56 Chevy with an LS swap. Very happy with the instructions, installation and performance. Planning to use them in my Suburban.
http://www.dakotadigital.com/index.c...rod/prd723.htm
Advanced Design is offline   Reply With Quote
Old 04-07-2015, 11:56 PM   #8
68c10airstream
68c10airstream's Avatar
ACII, if you want to use the pcm signal post your question to "critter". That's his avatar name, he's terry from lone star dyno. I changed from a 5,000 rpm tach to an 8,000 tach when i did a ls1 nova gauge cluster mod and the 5,000 rpm tach was spastic when i put in the ls. Terry was great to work with and his attention to detail is right on the money. The stock pcm tach signal can be scaled up to a higher voltage level if i remember correctly, but get with terry.
68c10airstream is offline   Reply With Quote
Old 04-12-2015, 04:07 AM   #9
ACII
thanks for that advise...i will get in contact with Terry.
I will kee u updated about the installations .-)
cu
Achim
