![]() Join Date: Sep 2014
Emergency Brake Cables with Rear Disks
I plan to upgrade to rear disk brakes that have an emergency brake. How have others set up their cables to accommodate rear disks? I will be starting from scratch and looking for tried and proven methods of routing the cables.
I bought "CaptainFab's" rear disc bracket kit, well laid out, included all fastener's. I bought the kit that uses pre '95 F body (Camaro/Firebird) calipers with integral E brakes. I got the calipers/brackets and cables from the local Pick n pull, but needed to buy new Caprice rear rotors. bolted up like a champ! the cables, I haven't mounted mine yet, but here's another forum members setup to show how he did it.....
HTH, Ben ![]() Last edited by snipescastle2; 04-15-2015 at 11:02 AM. Reason: adding pictures |
Re: Emergency Brake Cables with Rear Disks
I used the Tom's Classic (e-bay) kit with Eldorado (I think) calipers. They sent a longer center e-brake cable to route in the stock locations back to the rear control arms which then connected to the e-brake cables on the calipers.
I had to drill new holes for the braket on the control arm and move them but once I did that, everything worked perfectly. The calipers mounted and e-brake cables hooked up: I am really happy with them so far!
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
Old member
Here is a link for mine. I ordered the CPP kit with E brake. Came with everything you need.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=647684
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
