04-07-2015, 05:39 PM | #1 |
Question about 69 C30 wheels and options
I need to get some tires on my truck and I was looking at some options. I saw a post on a old thread that I can use 19.5 8 lug wheels and they will fit. I found some but they have 225/70-19.5 tires on them. The tires I have now are 215's so I want to make sure that they will not rub. Ok wait I just had a dumb realization, if they rubbed they wouldn't be on those wheels would they? Can someone confirm anyway. Also how do I know if I have the split rims? Here is a picture of mine and a picture of the ones I found for sale. Do they have to be old ones and how can I tell?
04-07-2015, 10:31 PM | #2 |
Re: Question about 69 C30 wheels and options
Here is a bump for you
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-08-2015, 07:16 AM | #3 |
The split wheels will have a ring around the wheel where one lip should be. Meaning if the wheel ring were missing there would be no edge for the tire bead to seat on/against. I have seen in other post on here that guys have used 19.5's on their trucks off of some P30's, I wanted to try that on mine as my 19.5 wheels has 7 new tires[who buys a new spare?] but my P30 was 5/10 lug set up. I don't know if the bigger wheels would have split rims you may want to look for some dually wheels they fit up to like 2000 or so according to Hollander[the salvages industries leading interchange source] but the lug bolts are bigger after like 72 or sometime in that range. Ford wheels will also fit but have a lining peg that has to be ground down or removed. Good luck with yours. Jim
04-08-2015, 07:17 AM | #4 |
Go to the dually picture thread you can learn a lot looking through it . It was close to the top just a day or two ago. Jim
04-08-2015, 02:22 PM | #5 |
So I cant tell if I have split rims unless the tires are off?
04-08-2015, 06:30 PM | #6 |
No, I'm not conveying properly the right way to tell you. Yes you can tell if the wheel is a lock wheel or split rim one side will have a part of the wheel[the part the beads rest against]with a ring that is separate from the wheel and it will have a slot in it. Think of it like a big snap ring, that goes on to the edge of the wheel. Look for the groove[split] in the wheel bead that will tell you if it is a split wheel. On my 71 C-30 it has 3 regular and three split wheels So I still need to find 3 regular to make mine right.Where did you come across the 8 lug P 30 wheels and what do they cost? I may try to look for a set myself.also just looked back at your pic, look for the split on the inside I think you will find it there. Jim
04-09-2015, 03:32 PM | #7 |
I didn't find any p30 wheels yet. Those wheels up there I found out came off a ford 450 super duty so I don't think they will fit. I would have had a sweet deal if they would.
04-09-2015, 04:38 PM | #8 |
I think you are right in that the newer 2002 and up Ferd wheels will not fit. They are 8 X 170mm I believe and we need 8 X 6.5 inch. I am also looking for wheels for my 68 dually.
"Life is too short to drive a boring vehicle". Later, Wayne |
04-09-2015, 05:45 PM | #9 |
Old Duffer
I'm sure you already know, but if you haven't done it, you may have to go to a 9/16's lug and captured washer lug nuts with other than stock wheels.....actually, it's not a bad idea with new wheels anyway.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
04-09-2015, 06:20 PM | #10 |
I am not sure, I will have to check. I swapped out my dually rearend with a 79 14 bolt full floater unit for better gearing.
04-09-2015, 06:26 PM | #11 |
Old Duffer
Most likely the 79 rear end is 9/16's. Are your front hubs stock? 1/2"?
04-09-2015, 05:59 PM | #12 |
You said the tires that you have now are 215s but the ones in the pictures are 245/70R16 or are you saying that you have 215s in 19.5 sizes? I think 19.5s only comes in 225 and 245 sizes but I could be wrong. I did a conversion on my C20 to accept front suspension and rear differential of a 1989 C3500. And I also located some P-30 wheels. The 225/70/19.5 fit nice and gives the truck a nice stance... but... I hate how it drives. If I had to do it all over again I would go with military 16 tires and forget about 19.5s. Of course my 19.5s are used tires so I you go with new one they may run much better.
04-09-2015, 07:12 PM | #13 |
Old Duffer
I'm sorry, I can't help you there. I checked two resources and one is dead wrong, (the very first line had '68 C20's with a 9/16 lug. When I got mine it was bone stock, with two piece wheels - [all six] - and 1/2" lugs.) The other was too vague to be helpful. (From 67 up into the '80's all it said was 1/2" or 9/16".)
Somebody that can tell us will jump in here pretty soon......
04-11-2015, 04:14 PM | #14 |
Those 245 tires were just rollers on the outside to get the truck home, you can't fit 2 side by side.
