04-07-2015, 07:29 PM | #1 |
2/4 drop question
I am planning a 2" front 4" rear drop on my short bed 66, I will be running 225/75/15 on 8" smoothies.
I have been looking at kits from CPP and Early Classic. The kits are similar with the adjustable trac bar and springs but 1 kit comes with shock relocators. Both mention what is needed for more than 6" of drop in rear. My question is for those who have done this drop, what is really needed for a 4" drop in the rear? Just a new trac bar and springs, or do i need the shock relocators? Thanks in advance |
04-07-2015, 09:45 PM | #2 |
Re: 2/4 drop question
For a 4" drop you shouldn't need a track bar or shock re locators. I think most people throw in an adjustable trac bar and relocate shocks when they hit 6" in the rear. I have a 4" drop with springs on my 66 and didn't need anything, but I put on an adjustable track bar anyway because I plan to go lower later
04-07-2015, 10:45 PM | #3 |
I used the deluxe 2/4 kit from E.C.E on my longbed. It came with relocators and KYB drop shocks. The ride is great. My friends with (ahem) more questionable drops always say, "I can't believe how smooth this thing rides" when they ride with me.
04-08-2015, 08:15 PM | #4 |
My experience was a better ride with the shock relocators. I started with a 4 inch drop and left the shocks in the stock location. The angle degree change is significant. As the suspension is lowered the shocks lay flatter to the ground. I put small zip ties on the shock shaft to measure the travel. I then installed the relocator kit and again and measured the travel distance. The ride felt better and the shock travel distance increased. The kit is inexpensive and in my opinion worth the time and money.
04-08-2015, 08:28 PM | #5 |
I'm running a 4" drop in the rear of mine at the moment. Stock panhard bar and stock shocks. 0 issues, with great ride.
I used ECE 4.5 front drop and have the 6" drop springs for the rear ...just haven't installed the rears yet Hope this helps
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 |
04-09-2015, 08:01 AM | #6 |
Before I lowered my truck 4" in the rear (long bed) I researched the exact same questions. The best answer I came up with everyones truck is differen. When lowered mine I ended up needing an adjustable track bar. I also installed shock relocators. My truck has an excellent smooth ride now.
It only has original paint once |
04-09-2015, 08:52 AM | #7 |
Moderator
Panhard bar - bolt on:
https://www.cachassisworks.com/p-261...nhard-bar.aspx http://www.speedwaymotors.com/Speedw...Kit,59078.html
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-09-2015 at 09:02 AM. |
