Old 04-08-2015, 12:54 PM   #1
C21EddieV
Tires rub, Help!
I have a 69 C10 Fleetside. Riding on 20/10's in the rear. As I make a turn they rub a little on the inside wall. Without having to go out and buy a new set of tires and wheels......is there something I can do to prevent this? I just bought this truck last Aug. Note; there's already a small spacer but it's not enough.
Ed Vasquez
Exclusive Properties
951-712-0601 Cell
909-992-3692 Efax
Email: c21eddiev@gmail.com
C21EddieV is offline   Reply With Quote
Old 04-08-2015, 12:55 PM   #2
WarMonger
WarMonger's Avatar
Re: Tires rub, Help!
Is there enough room on the outside for wheel spacers? push them out a bit and get some inside clearance.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 04-08-2015, 12:56 PM   #3
Smoothride
bigger spacer
Smoothride is offline   Reply With Quote
Old 04-08-2015, 05:43 PM   #4
Mike C
Mike C's Avatar
Originally Posted by smoothride View Post
bigger spacer
ftw!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-08-2015, 07:34 PM   #5
cdowns
cdowns's Avatar
detimine what is rubbing the tires and if it is possible to move it if not you need to move the tires
Old 04-08-2015, 08:30 PM   #6
71swb4x4
71swb4x4's Avatar
Can you keep the rearend from moving that much? Does it have a panhard bar? Rear sway bar? Poly bushings in the trailing arms and panhard bar? Whatever you can do to keep that rear from moving too much will help.
The panhard bar with poly bushings will help the most, probably poly bushings in trailing arms next and last the swaybar. A rear swaybar isn't going to help a lot, but it could help a little.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
