Old 04-12-2015, 03:09 PM   #1
Theoriginalsilverado
Exclamation Relocating the Ignition from the Column to the Dash?
Hey everyone, I'd like to thank you in advance for taking the time to read this post.
I've always loved the layout on older trucks in which the ignition is on the dash, usually just right of the column. Of course on our trucks, including mine, the more modern ignition in the column setup is found.
My truck is currently in about 10000000 pieces, and for your own enlightenment it's a 1975 Chevrolet C20 Silverado Camper Special. Quite a beautiful truck, with only 34000 km, and an entirely stock rebuilt motor sitting on a crate waiting to go back in my chassis.
My question is- does anyone know the process, or at least what would be required, to move the ignition from the column to the dashboard?
Like I said, my truck is currently completely torn down, so I can get at almost any piece I need to. If it's relatively simple/easy, I would like to do it before I begin the task of putting everything back together.
Thanks for your help.
If It runs like a Chevy, it probably is!
Theoriginalsilverado is offline   Reply With Quote
Old 04-12-2015, 07:02 PM   #2
greg64
greg64's Avatar
Re: Relocating the Ignition from the Column to the Dash?
Greetings. I've thought about this modification too. My 64 has the ignition switch on the dash and I like it. You can buy a key switch that has the usual off/acc/run/start positions, and once it is mounted where you want, then you'd need to run the appropriate wires to it. These wires are connected to the factory ignition switch that is on top of the column behind the dash. A real bear to get at. See the Restoring Rusty topic for recent pictures of the column disassembled.
But the problem, in my mind, is what do you do with the stock ignition switch location to clean it up? I guess you could use an earlier column, but that doesn't seem quite right to me.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-12-2015, 10:47 PM   #3
I was hoping to remove the stock ignition switch from the column, simply cover up the hole left by some means, and simply re run the wires to the stock ignition once I place it in the dash. Do you see any problems with this?
My main concerns are removing the stock ignition- I don't know if that's possible or not. Also, if I remember correctly, turning the key moves a mechanical type rod that activates something with the electrical, and this could cause trouble's for placement in the dash.
Old 04-12-2015, 10:58 PM   #4
greg64
greg64's Avatar
The ignition switch really has two parts; the key cylinder which is all mechanical, and connected by a rod to the actual electrical switch. The switch itself is linear and not rotary. I don't think you could reasonably use the stock parts with an in-dash key location. But there's really no need to, since there are common key switches with the electrical built in.
Greg
Old 04-13-2015, 07:59 AM   #5
Talking Re: Relocating the Ignition from the Column to the Dash?
So if I was to take the ignition setup from my dad's '69 which I assume has no mechanical rod type functionality, or bought a new replacement one for the 67-72 era, assuming those ignitions are all electrical with no mechanical rod, could I wire it to my truck?
I'm sure it's possible, but is it simple enough for me to do it?
I'd be ok with using the key with the new cylinder and not the stock one, as there are 2 keys now for the truck as it is- one for the ignition and one for the doors.
Thanks for the help Greg64
Old 04-13-2015, 08:51 AM   #6
andrewmp6
Some guys have swapped the 60-66 dash in these trucks,You could swap the dash and steering column.
Old 04-13-2015, 10:51 AM   #7
hatzie
Moderator
hatzie's Avatar
Van columns through at least 1979 have the IGN switch in the dash. Not sure if the column itself would be long enough tho...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-14-2015, 02:34 PM   #8
esbstuff
Don't forget the medium duty trucks are in the dash...73-up
esbstuff is offline   Reply With Quote
Old 04-14-2015, 03:29 PM   #9
greg64
greg64's Avatar
That's a good point. I wonder what their column piece looks like where we have the ignition switch?
Greg
Old 04-14-2015, 03:32 PM   #10
esbstuff
Its thin like a 67-72 truck. You would loose your locking column but the dash wiring should be a plug and play for a like year truck.
Old 04-14-2015, 06:49 PM   #11
hatzie
Moderator
hatzie's Avatar
Not sure that's much of a loss.
Old 04-14-2015, 07:33 PM   #12
Liberty
Liberty's Avatar
Haha nope! My locker wasn't put back in when I had the ignition repaired awhile back, I guess the lost the pin. I don't really notice or mind it being gone.
Liberty is offline   Reply With Quote
Old 04-14-2015, 11:37 PM   #13
My dad has a heavy duty truck that has the same interior as mine, one from the 80's I believe. Actually he has 2 know that I think of it! I assume that the wiring will be different though being from the 80's? Also the steering column may be too long... Although I have no idea I'm just speculating. But I can't remember seeing a spot in the dash for the keys either. I'll have to check into it
Old 04-14-2015, 03:35 PM   #14
greg64
greg64's Avatar
Interesting, thanks.
Greg
Old 04-15-2015, 11:41 AM   #15
jetmech85
The ignition switch is mounted between the radio and steering column and there is a raised portion moulded into the plastic dash bezel.
jetmech85 is offline   Reply With Quote
dashboard ignition, ignition
