04-13-2015, 08:34 AM | #1 |
Wheels and Factory Caps Question
I need a little help from the wheel gurus.
I picked up a super nice set of wheels awhile back. Standard 15" GM 6-lug measuring approximately 6-1/2" from lip to lip on the width and about 8" across the inside of the recessed lug area. I really want to run the factory style caps on these wheels, but at this point I'm really confused as to what caps I need to be looking for and rather or not I need to install clips on these wheels before i have them painted/powder coated. These are the factory caps I like. I know there is some difference between 1/2 ton and 3/4 ton, 64, 65, and 66. Someone just tell me what my options are and if I knew what wheels I actually have, that would probably be helpful also. Thanks for any clarification on this stuff. I'm lost at this point. THANKS!
scootermcrad.blogspot.com |
04-13-2015, 08:43 AM | #2 |
Re: Wheels and Factory Caps Question
The caps you need will be the 15" caps that measure 10 1/4" on the back or you can use a 16" cap and remove the back inner ring. The 15" cap with the open back 10 1/4" would be easier to source.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-13-2015, 09:00 AM | #3 |
Okay. Good info! Will I need to add clips to my wheels, or do those 15 caps just pop right on?
04-13-2015, 08:43 AM | #4 |
04-13-2015, 09:00 AM | #5 | |
04-13-2015, 09:05 AM | #6 |
No....you have the 3 nubs on your rims that will hold on the caps. The clips go on the wheels that do not have the 3 or 4 nubs depending on year of manufacture of the rim.
04-13-2015, 09:21 AM | #7 |
The caps you have pictured are 64-65 caps, 66 have a rib around the edge.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
04-13-2015, 09:43 AM | #8 | |
So, it sounds like I'm after 64-65 caps that measure 10-1/4"? That definitely seems to jive with the dimensions I have. Great! This is the look I'm after, right here. White 64-65 cap with black on black tire and wheel combo.
04-13-2015, 09:52 AM | #9 |
So... finding a set will be fun. HAHA
04-13-2015, 10:44 AM | #10 |
This is what the back of the caps I need will look like, correct?
04-13-2015, 10:46 AM | #11 |
yup
04-13-2015, 11:27 AM | #12 |
Great! Thank you!
I really appreciate everyone's help with the info. I feel like I know exactly what I need. Wheels will go off for coating!
