04-14-2015, 10:28 AM | #1 |
Lowering my truck
I have a 69 c10 swb and I'm trying to lower it just enought to close the wheel wells how should I do it with springs on front and back? Or what?????
04-14-2015, 11:16 AM | #2 |
Re: Lowering my truck
Get 5" drop springs for the rear (about 100 bucks) and cut 1.5-2 coils off the front. That's the cheap way, you can easily get carried away with air ride and c notches. Here's a truck I did with the setup described above
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
04-14-2015, 11:18 AM | #3 |
04-14-2015, 12:35 PM | #4 |
04-14-2015, 12:10 PM | #5 |
I am in the process of doing this on my 69 as well. I am also doing a disk brake conversion, so I have a few more steps involved. I'm taking the entire front suspension, rear axle, and brake system off of a 71 parts truck and putting them on my 69. In the process, I am adding 2" drop springs in the front (and now probably 2.5" drop spindles as well), and 4" drop springs with a 2" lowering block in the rear. Should give me a 4.5" drop in front and 6" in the rear.
1969 Chevy CST/10 396, PS, PB, A/C |
04-17-2015, 12:35 PM | #6 |
5 inch rear spring - 2 1/2 inch ECE drop spindle in front with 1 round cut off the top of the spring.
1969 swb. 5.7 TBI. 700r4 255/50r17 on AR PVD coated rims Last edited by Smokinhart; 04-17-2015 at 12:52 PM. |
04-17-2015, 01:04 PM | #7 |
I cut the front springs one coil also. worked ok but, we barley got the trk aligined and rides a bit rough. next time I'll use 2 " drop spindles for sure.
04-20-2015, 05:34 PM | #8 |
Thanks guys I just ordered the lowering kit from brother classic Chevy
Posted via Mobile Device |
04-20-2015, 07:10 PM | #9 |
67-72 parts collector,…
Don't forget:
Drop shocks Rear shock relocators Adjustable track bar. It more than just spindles and springs.
04-20-2015, 07:18 PM | #10 |
So true. Before you know it you stripped it to the frame to paint it all semi gloss black and you have drop blocks, drop spindles, all new moog parts for the front end and it's still in pieces. Lol. It's a sickness I tell you! 😃
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E I call it Bruce Banner.. |
04-20-2015, 08:37 PM | #11 |
04-20-2015, 08:51 PM | #12 |
Well, come to think of it... Yes....lolife and trkenvy sickness it is. I also did the drop shocks front and back. Rear and front shock relocator mounts, plus early classics tube trailing arms. 1 inch drop block too.. Sway bars front and back... Carried away. Couldn't leave good enough alone. The list got so long I don't want to remember it all. Then two years later it still hasn't seen the road yet. But, every part out of the supply cabinet is one step closer to bustin bugs. I'm 3 good weekends away from a test run. Just took most of 8 years to get to the turn. Next truck in waiting is AC '72 long bed with documented 88,000 on the roll. One out of the shop one in. This next one isn't getting the lowering and spindle packages. It's definitely going DD route.
