Battery fell out... Truck won't start.
So I finally got my truck back together after swapping over to a 4-speed, installing a 4 inch lift, and blowing the bank on some new wheels and 35s. I jumped the gun a bit and decided to tear up the trails at my house as soon as it was together just enough. It was a complete beast until I went up a really steep hill climb, made it up just fine but stalled out about a minute after the climb. opened the hood and the battery was gone! Turns out, it fell out when I went up the hill climb and I'm guessing my truck was running on the alternator until the positive terminal shorted on something? I put the battery back in and it cranks fine but no spark... I tried a new coil, a new wire to the distributor, nothing. I'm getting power to the coil and I have electric ignition. Could I have blown that up? I'm pissed I didn't take an extra 20 minutes to bolt the wheel tubs in, or at least but a bungee around the battery!
Re: Battery fell out... Truck won't start.
Fusible links.. fuses.. melted wires.. lots could have happened. You will need to start tracing from the starter into the dash.
Everything is still torn apart. I just rewired pretty much everything and the wiring is still exposed for the most part. I looked it over and didn't see anything out of the ordinary. I'm getting good voltage to the coil so I didn't look too hard. I did check the plug to the ignition and I didn't see anything melted or burnt.
I have had a fried capacitor, or my module on an HEI. I can't tell you the specific culprit because I completely rebuilt my distributor, but I can tell you it was narrowed down to those two components. The truck just had no spark. It cranked strong, got fuel, and a multimeter read full voltage to my distributor plug-in, but one look at a spark plug while cranking verified- NO SPARK!
I bought one of those Proform HEI tune-up kits from Pep Boys because that's the company GM performance parts uses for their basic crate motor distributors. 20 minutes later the truck fired up and ran stronger than it ever had. |
Do they make those for 6 cylinders? My truck is a 292
I don't think so, but it would be pretty easy for you to piece together the individual parts.
My vote is module
ignition module fried?
![]() Join Date: Feb 2002
I think the HEI Module is the same V8 or L6. I would first look at the diodes in the alternator or at the external voltage regulater if you have one. Those are more likely to burn out if your battery is out of circuit, or there's a short.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-17-2015 at 12:44 AM. |
If your getting 12v at the distributor wiring connection, then it has to be something inside the distributor...ie the ignition module or coil. The ignition module is the weak link.
