04-18-2015, 05:37 PM | #1 |
Has fuel but not starting?
I recently got a 1970 C10 and was running fine after rewiring the entire truck. it's been about a month and now it fires up and then stalls out. And then after trying to start it again, there is nothing. I have already replaced the inline fuel filter and the fuel pump. Could the issue be the sending unit in the tank?
Any help would be appreciated.
1970 Chevy C10 |
04-18-2015, 07:47 PM | #2 | |
The Older Generation
Re: Has fuel but not starting?
LockDoc
10-04-2015, 10:21 AM | #3 |
Hey everyone,
I finally figured out the issue with no fuel but will have to replace the gas tank for it to be fully operational as I think rust is getting into the line and causing blockage to the carburetor. (I replaced the fuel pump, lines and rebuilt the carb and found the rust lying in the bottom) I pulled out the heater core and blower as it is not working and will need to replace but what should I do with the hoses that were connected to it? I am thinking of just rerouting the hose from the water pump but not entirely sure. Any help would be appreciated.
1970 Chevy C10 |
10-04-2015, 10:29 AM | #4 |
I assume you are going to replace the heater core soon, so for now you can just connect those two hoses. They are different sizes so you will need to get a little creative with your adapters. But then when you install the new heater core it's easy to hook back up.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-04-2015, 11:22 AM | #5 |
Okay, I was wondering if I was able to do that or would need to plug it. Appreciate the help.
1970 Chevy C10 |
10-07-2015, 11:20 AM | #6 |
I used a piece of copper sink tube, with 3 O clamps on each side. Did the trick for a few years. Then I bought $.99 brass plugs from NAPA. Screwed them in.
good to have in glove box too! Ever blow a hose just plug and go.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
