Old 04-19-2015, 01:04 AM   #1
In The Ten Ring
Back on the fuel line: more questions.
So I am back working on the truck. (Replacing the entire fuel line). Today I tried my Craftsman double flare tool and it works BUT doesn't make a "bubble flare."
I really want to flare my fuel line ends but do I need a bubble flare? Can I get it to join to rubber hose with just a single flare?
Today's bending....
The ridges from the clamping tool.....are those OK?
In The Ten Ring is offline   Reply With Quote
Old 04-19-2015, 01:35 AM   #2
leftybass209
leftybass209's Avatar
Re: Back on the fuel line: more questions.
I didn't use a bubble flare on mine and it's been going strong without a drip. I just did a single flare and tightened the clamps just after the flare.
leftybass209 is offline   Reply With Quote
Old 04-19-2015, 06:38 AM   #3
dirtyjim
dirtyjim's Avatar
some flare tools will make a bubble if you only use the first stage of the double flare, my eastwood does but they aint cheap
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 04-19-2015, 01:35 PM   #4
In The Ten Ring
Well if a single flare will work, then I'm OK. I wanted a bubble flare, thinking it would be easier to get the hose to go over a bubble as opposed to a single but if it will, then I'll do it.
I am using Poly Armor tubing, which is hard to flare it seems as it is so hard, so my kit may not bubble at all. I have a Craftsman 45 degree double flare kit.
I saw the video on the Eastwood turret set and I really liked it but for the money, I don't know if I'd use it again. Well...I might use it on my Pontiac to make new lines but that's a different story.
I'll try and see if I can get some tubing to slide over my test flare today and if it goes on easily enough, I'll go on.
Old 04-19-2015, 06:48 PM   #5
leftybass209
I used the same poly armor stuff. It's hard to work with, but the hose will slip right over a single flare with no trouble. I've done it now 4 times, and haven't had a leak on any of the points. I personally use 2 clamps a piece. I tighten one down after the flare, ensure that there's no leaks with the one, then add an another about a half inch apart to satisfy my worry.
Old 04-19-2015, 06:58 PM   #6
In The Ten Ring
My hoses aren't slipping over very easily at all! I just tried it. I am so annoyed I am ready to forgo flaring the pieces all together!
Someone else posted that a basic double flare kit could do a bubble if I use the other (flat) side of the clamp so I am going to give that a shot first. I'd like to be flared on this thing if I could.
Old 04-19-2015, 07:32 PM   #7
Ruscal
A double flare tool's first stage will work well. You can also use a tube beading tool like this one from Summit.
http://www.summitracing.com/parts/ea...FcVgfgodfrYAOQ
The clamping block from flaring tools do cause a little trauma to the tube just below the flare. I have not seen any problems from that.
Ruscal is offline   Reply With Quote
