wiring nelp
![]() for a electronic ignition. Can't get the truck to start with the key I'm just lost HELP. changed from point to electronic ignition ![]()
C/10 John N.J. |
first thing is you eliminate the yellow wire at the starter, then you take the yellow wire at the coil go back thru the wire loom find the spot in the firewall junction box it goes to then remove it and replace it with a new length of 12gauge wire and you'll be good to go . the reason you have to replace the original is that the original wire is a resistor and only supplys 7volts to the coil
Glowing since 1978
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
its all about the +6 inches
Do you have the wire in the proper terminal on the HEI cap?
If everything looks good, then check your plug wires and make sure the fireing order is right and that they are in the correct location. |
